Thread: backlash mack3
27-01-2011 #1
backlash compensation in mach3 any one use it? if not why?
there is no such thing as a stupid question, just stupid answers !!!!
27-01-2011 #2
I don't use it as I have ballscrews so I don't have to.
Phil
Sent from my HTC Desire using Tapatalk
28-01-2011 #3
I almost always use it. If, for instance, you're drilling an array of holes it will clearly make a difference to the accuracy - unless you're careful with the Gcode.
I've found in some instances it is of limited value since the backlash wont be a constant value.
Be careful with the velocity and 'shuttle accelaration' settings. The motors will loose steps with too low a setting for the latter, however to high a value will make the motion less smooth.
Have you got two ballnuts preloaded on each screw then? Or just sufficiently low backlash to ignore it with one?Last edited by Jonathan; 28-01-2011 at 02:07 AM.
28-01-2011 #4
28-01-2011 #5
Phil why don't you use backlash compensation to get rid of the 0.05mm?
i had 0.5mm now got it down to 0.02there is no such thing as a stupid question, just stupid answers !!!!
28-01-2011 #6
I did try but the machine in my mind didn't benefit, it sounded weird.
Parts i make come out perfect for me, so in my case it wasn't worth it. I also have a manual Bridgeport i can get better accuracy on the RF31 a lot easier.
All machines have some backlash, especially on a hobby machine if you think you have Zero backlash then you are not measuring correctly.
There is no substitute for almost zero backlash, software will do a job on small cuts but if you are taking big cuts with large amounts of backlash the cutter is going to be drawn in (Snatch) when climb milling and the potential is to lose position.
Also when climb milling with ballscrews the cutter is moving the table and the stepper is controlling the movement so you do not need as much stepper motor power.
When conventional milling the stepper has to fight the forces of the cutting action so you need a powerful motor.
Chris i know you have a mill already and you can tell how much extra force you need when manual milling in the conventional direction. You also get the best finish with climb milling.
Phil
28-01-2011 #7
thanks Phil a good read that nice 1.
29-01-2011 #8
29-01-2011 #9
don't know if you've seen this Phil shows how to setup so no weird sounds and runs sweet.
The Following User Says Thank You to h4ppy-chris For This Useful Post:
29-01-2011 #10
Micro lathe Zero backlash* conversion
By Jonathan in forum Lathes, Lathe Rebuilding & ConversionsReplies: 14Last Post: 22-09-2012, 10:56 PM -
Is this an example of what backlash can do?
By Minnican in forum Machine DiscussionReplies: 19Last Post: 06-03-2011, 08:59 PM -
Sieg X3 backlash...
By Vikash in forum General DiscussionReplies: 0Last Post: 20-10-2010, 02:51 PM -
Positive backlash???
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 18-08-2010, 05:04 PM -
Sieg C3 backlash problem
By Cret in forum Milling Machines, Builds & ConversionsReplies: 10Last Post: 08-09-2009, 07:18 AM
