Thread: Need some ideas
    Quote Originally Posted by jpcnc View Post
    I was thinking along those lines too, it would however need some kind of constant presure to ffed it in though.
    You making an offer phil ??
    JP i am more than certain my idea would work, you would need some varied machinery to do it but it is easy enough i don't know if you have the required machinery to be able to make it though.
    As this is a commercial enterprise i think some reward would be good for the best idea seeing how you will be making a shed load of money. :lol:
    Phil
    I have a precision engineering company that has the machines to make most of the parts I need, its just weighing up the cost though as I can still sell this as it is, as I mentioned this is just a waste product of my other machine service, if I can sell it or make something with it then its an extra bonus
    You should have no problems then.
    Do you want to know my idea ?
    Phil
    Yeah come on then lets have a listen...lol
    Another idea I hed was a cylinder with a very abrasive rotating flat disc to almost grind it away into a heavy dust?
  5. #15
    You have say five rubber faced rollers set two over three, similar to Olympic games emblem, in the centre of the rollers is a groove, this groove forms a channel to feed the cord to the die.
    The rollers are 24mm diam they then feed the cord to a die the other side of the die is a rotating disk with six holes that form a shearing/scissor action.
    The rollers and the disk are geared to run together, so one revolution of the rollers cuts 6 pieces of rubber at 4mm long, at 200 RPM you are cutting 4.8 metres per minute.
    Phil
  6. #16
    Theres one big flaw with this, my waste strings are going to be in one big messy pile, your idea would mean keeping the lengths seperate then manually feeding each one into the rollers, im looking to pick up a big bunch at a time and stuff it in
  7. #17
    What about a simple rotary cutter. Cutting disc with maybe 3 or 4 vent type cutters mounted on a motor shaft ( similar idea to a food mixer disc ? ). A tube could be used to feed to rubber to the cutter. Feed pressure supplied by a couple of rubber wheels.
    Regards
    Ian
    Just read the last couple of posts. Need to type faster!!
  8. #18
    i2i's Avatar
    an oversized paper shredder with a funnel, would do the job
  9. #19
    I knew you were going to say that.
    As the cord is cut it will be fed into the chopper.
    While the operator is attending the machine he will be sorting the pile.
    Phil
    Sent from my HTC Desire using Tapatalk
  10. #20
    that depends on the nature of the cuttings, it also means adapting my machine which id rather not now
  1. New Gantry Ideas
    By Tomnewry in forum Gantry/Router Machines & Building
    Last Post: 05-02-2014, 09:00 PM
  2. BUILD LOG: 5'x3' Ideas and build.
    By Wal in forum DIY Router Build Logs
    Last Post: 29-12-2012, 01:03 AM
  3. New machine Ideas
    By jcb121 in forum Gantry/Router Machines & Building
    Last Post: 19-09-2012, 09:18 AM
  4. Ideas and inspiration....?
    By Tom in forum General Discussion
    Last Post: 10-08-2010, 12:09 AM
  5. Any ideas on the best use of this????
    By Ross77 in forum Gantry/Router Machines & Building
    Last Post: 01-08-2010, 10:41 AM
