Page 3 of 7 FirstFirst 12345 ... LastLast
  1. #21
    Impractically quick! (and dangerous!). Usually cut wood between 5 and 20 depending how deep. Bellows came with the unit (Isel), 20 years old now. They are actuall just folded with U shaped thin plastic formers glued in the folds.
    Tom
    Sherline lathe, Chester DB11V lathe, Myford/ Rodney mill, CNC mill Isel/ home made, Sealy Hack Saw, Meddings Pillar drill.
  2. #22
    Me again
    I replaced the 20mm linear shafting and it certainly tightened it up.
    Replaced the X, Y ball screws and doubled up on the nuts to add a 1kN preload :naughty:
    The ebay M8x.75 half nuts I bought on Monday haven't arrived. Can't thread the ballscrews 'til I have the nuts or it suddenly becomes guesswork for the length and die closure.
    A very nice man at bellevillesprings.com gave me half a dozen washers to preload the thrust bearings. Their £15 minimum order translated in to 150 pcs :whistling:
    The metal for the splash guards did arrive so I will probably start on that.
    Pic is the bed and saddle upside down.
  3. #23
    I've extended the table 2" forwards with a lip. Then I decided that driving my Warco mill using MSDOS was a right PITA after seeing what Windows 7 can do with this thing.
    I have the new software about 80% complete so I'm going to do that before I cut the splashguards. It takes a DXF file, converts it to a cut and then drives the mill.
    Back in a few weeks, if I don't get sidetracked again :whistling:
    Robin
  4. #24
    Me again
    Splash guards fitted and looking a bit '70s retro.
    An IP65 sealed box bolted to the right hand end is the suds tank, I'm using the Tee slot as a gutter.
    Next, sealing it with gasket compound and cutting some slots in the bed so I can fit tee nuts from above and improve the drainage.
    Robin
  5. #25
    i love this little machine..
    What materials are you going to cut with this and what sort of things are you going to produce?
  6. #26
    Quote Originally Posted by cooliced View Post
    You asked me that before, you want me to be more specific? :naughty:
    Specifically, I plan to cut Alumec and make injection tooling.
    Alumec is a sort of improved 7075 T6 alloy in 3 grades which can hold a deeper temper. Get it from Blackburn metals.
  7. #27
    Ah so i did.
    Sounds very interesting. keep it up mate
  8. #28
    Hi Robin,
    I have an old PNC3000 at home, used it few years ago but EPROMS seem to be dead now (25 years old...).
    I understand you have reprogrammed yours, and I would like to give another life to my machine.
    Do you know where I can find the original EPROM content?
    On the longer run, I would like to replace all this venerable electronics with a Raspberry PI + some kind of controller board (the one used on 3D printers or a custom designed one, linux enabled if possible). Do you know about such initiatives?
    Many thanks for your help
    Kind Regards
    Jean
  9. #29
    New motor and ER-16 chuck fitted. Used cheap bearings which are running noisy and a tadge warm, I'll give them a few hours and if they don't settle down and start behaving I'll have to shell out for something more up-market :whistling:
    Hi Robin Hewitt - Can you please tell me the actual manufactures part numbers for the DC Motor and the ER16 spindle you placed in your Roland CAMM3 PNC-3000. Additionally, can you please provide me both pulley part numbers along with the belt you used.
  10. #30
    Hi Jean,
    Are you looking into selling the machine? I would be interested in buying it.
    Regards,
    Alex
  1. NEW MEMBER: Yorkshire based modding / hacking noob says hello
    By dynamis_dk in forum New Member Introductions
    Last Post: 27-02-2014, 11:03 PM
  2. FOR SALE: Roland CAMM3 PNC-3000 Desktop Mill
    By danielbriggs in forum Items For Sale
    Last Post: 25-01-2012, 06:14 PM
  3. FOR SALE: For Sale! Roland PNC 3000 milling machine
    By fidia in forum Items For Sale
    Last Post: 26-07-2011, 10:07 PM
  4. NEW MEMBER: Hi From Oxfordshire - with Roland CAMM3 machine
    By rowifi in forum New Member Introductions
    Last Post: 15-02-2011, 05:04 AM
  5. Cheap for hacking
    By Robin Hewitt in forum General Discussion
    Last Post: 21-11-2008, 01:30 PM
