    Hi....
    So I decided to try and mill a sphere as a test piece to check the functioning of my mill and the software I'm using. I figured a sphere would be tough - and I turned out to be correct.
    I'm using Vectric Cut3D to produce the toolpath and Mach3 to control the mill.
    I used a piece of pine 70mmx70mmx43mm and aimed for a sphere 40mm in diameter.
    However, it became very obvious on the 2nd pass that the circles being left after each pass were not concentric. I could see clearly that when Mach3 said the X-axis was at 70mm it was in fact probably 75mm!! It seems as though Mach3 no longer knew where the exact position of the mill was. I shut the mill off when it became apparent that the Z-axis had suffered the same fate.
    Here's the piece after about 12 roughing passes.
    It's a mess:
    Does anyone have any ideas why this may have occurred and possible solutions please?
    Is this backlash at work?
    Regards
    Simon
    HOLY S**T!!!!:rofl:
    dont you just hate it when that happens!
    looks like the mountain off close encouters :)
    looks like a shitload of lost stepps to me
    id zero your tool and DRO's in mach on a point rapid XYandZ back and forth for a spell and get mach to go back to zero
    im gussing it will stop miles away from your refrence point, if it dose you need to back off your rapid speed in motor tuning
    going off what you are saying, if its reading +70 on the X axis and is more like +75 then your losing stepps when the X axis is moving in the minus direction, it maybe during a rapid or during a cut (cant tell without seeing the tool path)
    what ever it is you need to lower friction on your X axis or stop driving your X stepper so hard
    Ok... thanks for that..... I'll try that right now....!!
    And yes... it's the worst example of a sphere I've ever seen.... mind you it's first attempt at anything on the mill.....
    Quote Originally Posted by Minnican View Post
    all part and parcel of building a cnc in my opinion, i think we have all had our share of disasters but yours has really tickled me, i actualy laughed out loud when i saw that picture.... it reminds me that im not alone on the planet
    it looks like it will be a pretty simple fix with a bit of messing about in motor tuning
    let us know if you manage to carve anymore square spheres :)
    Oh.... and feed rate box on mach3 reads:
    FRO=6.00
    F=6.00
    100%
    units/min=0.00
    units/rev=0.00
    I have no idea what any of that means...!!!
    Looks more like lost steps to me. Backlash would have the circles concentric but not circular.
    You could try it at a lower feed rate to see if it's lack of power in the steppers.
    A more scientific test is to put a dial gauge against the axis, creep up to a sensible setting and then rapid traverse away from it then come back to the same position at a low feed rate. The dial gauge should have the same reading.
    If it's happening on all axes with no pattern it might be noise or if it's happening when doing moves on all axes it might be the power supply struggling.
    Have you tuned the top speed and acceleration settings of Mach3? What are you using for steppers / drivers / power supply and what feed rates were you using?
    Ok..... suggestions thick and fast...... I like it.
    Right, after zeroing and whizzing around on all axis.... the DRO's no longer correspond with the home. X=-1.3675mm; Y=-0.5475 and Z=+1.9063, all approximate figures.
    I looked at the setup of the motors and see: X-axis "steps per"= 800; "velocity"= 1500; "acceleration"=200; "step pulse"= 5; "dir pulse"=3
    Y-axis "steps per"= 800; "velocity"= 1500; "acceleration"=200; "step pulse"= 5; "dir pulse"=3
    Z-axis "steps per"= 800; "velocity"= 700.2; "acceleration"=100; "step pulse"= 5; "dir pulse"=3
    Velocity and acceleration in the above is mm.
    The stepper motors are 57BYGH488 1.8 degrees and 2.5A. Can't really answer regarding drivers and power supply as I'm not sure where to find this info.
    Yep..... the photo's certainly worthy of a giggle...... I did..... after the cursing!!!
    1500 sounds a bit quick for a mill using 2.5A steppers
    id leave the other settings for now and work on the velocity
    i would have though below 800 on all and try again
    if it works well up them bit by bit and visa versa
    The fact that all three axes are loosing steps is suspicious but the feed rates do seem high so that might explain it - are you running ball screws. Where did the configuration parameters come from?
    I use EMC2 and don't know much about Mach 3 but a quick skim of the manual found a couple of references to step pulse width and inversion...
    "Pulse width is another consideration. Most drives will work well with a 1 microsecond minimum pulse
    width. If you have problems with the test moves (e.g. motor seems too noisy), first check that your step
    pulses are not inverted (by Low active being set incorrectly for Step on the Ports and Pins>Motor
    Outputs tab), then you might try increasing the pulse width to, say, 5 microseconds. The Step and
    Direction interface is very simple but, because it can still “sort of work” when configured badly, it can
    be difficult to fault-find without being very systematic and/or looking at the pulses with an oscillo-
    scope."
    So if the motors sound rough at moderate feed rates it might be worth checking that the low active or high active setting is set to match your drivers. What machine is it you've got? Are there any technical documents with it?
    As Mark says, it's all part of the learning experience - I've got a couple of parts on the mill that need remaking due to it loosing steps while I was making the parts needed to stop it loosing steps :-)
    I'm no expert but have you set up the machine correctly? It seems to me that the machine is moving further than it thinks. Double check that you have set the number of steps per linear measurement correctly. These may not all be identical by the way. What works for the X-Axis might not be right for the others etc.
    Martin.
  1. Micro lathe Zero backlash* conversion
    By Jonathan in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 22-09-2012, 10:56 PM
  2. backlash mack3
    By h4ppy-chris in forum General Discussion
    Last Post: 29-01-2011, 01:11 PM
  3. Sieg X3 backlash...
    By Vikash in forum General Discussion
    Last Post: 20-10-2010, 02:51 PM
  4. Positive backlash???
    Last Post: 18-08-2010, 05:04 PM
  5. Sieg C3 backlash problem
    By Cret in forum Milling Machines, Builds & Conversions
    Last Post: 08-09-2009, 07:18 AM
