  1. Good day all.
    I have been making my own pcb's on and off for the last few years via the toner xfer, and uv methered.
    I am now also looking at trying to make quick prototypes using PCB Isolation Routing.
    I have only ever used a program called DipTrace for designing the PCB's and as far as I can tell it can not output g-code for isolation routing.
    Can anyone please advice what software I might need, and how I go about doing it.
    Thanks for your time.
    Best Regards.
    "If first you don't succeed, redefine success"
    C_Bubba's Avatar
    Lives in LaGrange, GA USA, United States. Last Activity: 14 Hours Ago Has been a member for 9-10 years. Has a total post count of 78. Received thanks 10 times, giving thanks to others 2 times.
    I use Eagle (www.cadsoft.de) to design the schematic/board and then use a freeware pcb-gcode.ulp to output the isolation, drilling, milling g-code files.
    Eagle has a freeware limited edition that will do boards up to 100mm by 80mm and 2 layers.
    There are also a yahoo groups for supporting Eagle and the pcb-gcode ulp.
    Art
    AKA Country Bubba
    (Older than Dirt)
  3. Thanks for that, I have found that each time I look on google regarding pcb isolation routing. I always seem to be heading back to eagle.
    The current board I am wanting to make is a duel layer board 152x294mm.
    djc's Avatar
    Location unknown. Last Activity: 07-06-2011 Has been a member for 9-10 years. Has a total post count of 12.
    Quote Originally Posted by Mad Professor View Post
    If you like DipTrace, stick with it. Even though it seems more widely used, I couldn't get on with Eagle.
    As I understand it, DipTrace will output DXF files. There are many free or inexpensive CAM programs that will go from DXF to G-code.
    Start here:
    http://www.freebyte.com/cad/cadcam.htm
    (Don't try a Google search for 'free CAM')
  1. BOB 3 Axis, optical isolation
    By thjremy in forum Electronic Project Building
    Last Post: 05-01-2014, 04:15 PM
  2. Break board 3-axis optical isolation, simple!
    Last Post: 06-04-2013, 04:42 PM
  3. PCB Isolation Routing
    By CHudson in forum Milling Machines, Builds & Conversions
    Last Post: 10-10-2010, 08:34 PM
  4. BUILD LOG: routing 3d?
    By proddy in forum DIY Router Build Logs
    Last Post: 03-08-2009, 11:20 PM
