    Hi all I just received a Boxford TLC 125 that I bought of ebay.
    Unfortunately somebody has already disassembled the ball screw bearings (luckily not the actual ball nut) on re assembly they have managed to get a really notchy feel in the end bearings. I looked on the boxford website under spares http://www.boxford-software.com/spar...BallScrews.php the description there seems to indicate that I should have a needle roller thrust bearing in the assembly somewhere. However my end block (part TCL-05-012A at the above link) has two deep groove ball bearings pushed into it. Can anybody tell me what I should actually have in there and in what order they go. For instance should I have two ball bearings and the thrust bearing ? should I have two of part BR-AS0619 ?
    Any links to drawings or documention would be a great help I recieved absolutely no papaerwork with the lathe.
    Regards
    Lamestllama
    HI, unfortunatly i cannot answer this quesstion but it would be good to see any drawings of the machine if anybody does have them
    There is a company on the tinterweb that retro fits TCL 125 but i havent even herd back from them
    i2i's Avatar
    Lives in Cardiff, United Kingdom. Last Activity: 30-08-2018 Has been a member for 9-10 years. Has a total post count of 693. Received thanks 30 times, giving thanks to others 0 times.
    in the larger boxfords they have two angular contact bearings opposite each other to locate the ballscrew in the top plate.
  1. taper roller bearings vs deep groove ball bearings
    By dsc in forum Linear & Rotary Motion
    Last Post: 10-03-2014, 07:06 AM
  2. bearings and ballscrew dont fit each other
    By marbles in forum Lead Screws, Nuts & Supports
    Last Post: 09-02-2013, 05:06 PM
  3. FOR SALE: Vee Bearings.. 16 off un-used...
    By fasteddy in forum Items For Sale
    Last Post: 21-06-2011, 08:01 AM
  4. Ballscrew Support Bearings - Angular or Self Align or ??
    By williamturner1 in forum Lead Screws, Nuts & Supports
    Last Post: 02-10-2010, 01:38 PM
  5. Bearings(Rotary)
    By GeorgeD in forum Linear & Rotary Motion
    Last Post: 14-08-2010, 04:50 PM
