    I've been thinking about how to attach bearings and a timing pulley to a ballnut such that it can be rotated with a stepper motor, instead of rotating the screw.
    I've already done this on my router with an M20 screw since the long X-axis means that screw whip and inertia would have limited the speed significantly:
    This is, I think, the most promising design I've come up with for rotating a ballnut. The chosen ballnut is the standard RM2510 ballnut from linearmotionbearings eBay seller (among others). The diameter of the ballnut and screw would makes angular contact bearings quite costly. At first I drew it with the ballnut inside the bearings, however the following design allows for smaller 6007 bearings and also gives the option of putting 2 ballnuts in to eliminate backlash. One ballnut attached to either side of the shaft.
    Here it is:
    (I'll draw it in 3D if necessary)
Name:	RM2510 Rotating ballnut mount.png
    Black is ballnut/screw/bearings
    Red is shaft, steel or aluminium - probably aluminium since lower moment of inertia.
    Orange is thingy that fits on the end of the shaft and attaches to the ballnut via the 6 holes in the ballnut.
    Green is some aluminum plate to hold every thing. One plate will be extended to accommodate the stepper motor.
    Brown is timing pulley. I could machine the pulley on to the shaft, however that means making a new shaft if I get the number of teeth wrong.
    Blue is a collar bolted to the aluminium plate to preload the bearings.
    Any comments/ideas/criticism welcome!
  2. The Following User Says Thank You to Jonathan For This Useful Post:
  1. Rotating Ball nut
    By drumsticksplinter in forum Lead Screws, Nuts & Supports
    Last Post: 12-05-2020, 08:01 PM
  2. Replies: 15
  3. Rotating Ballnut Design MK3
    By Jonathan in forum Linear & Rotary Assemblies
    Last Post: 15-12-2013, 01:35 PM
  4. advice on floating bearing - outer ting rotating
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 18-11-2013, 02:23 PM
