Thread: Rotating Ballnut - design ideas
10-04-2011 #9
The bearing I used is a 3208 double row angular contact.
Normal bearings, which includes double row ones, aren't really suited to applications with lateral loads. Deep grove bearings are better, but still not ideal.
However, most common angular contact bearings are the same physical size as normal bearings, so you can always switch to angular contact at a later date.
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
