Thread: Rotating Ballnut - design ideas
26-07-2012 #10
Yes I can, depending on how soon you need them.
A rotating ballnut would be ideal with the a 2020, 3000mm long screw. Since (I gather) this is a woodworking machine, you would probably want to gear it 2:1 so the gantry moves 10mm for every motor revolution.
Here's one I made recently, version 3 I suppose. The significant change is using sealed angular contact bearings (turns out they do exist) and threading the shaft to enable a pair of locknuts to pre-load the bearings.
Will post a video when I have time.Last edited by Jonathan; 12-09-2012 at 02:43 PM. Reason: Attachments never appeared
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
