    Hi my hand router broke and I need to program my ELU 860 CNC by hand as I have not got it working from the computer yet. I need to do a circle with a 90mm diameter and a cut out depth of 18mm. Can any one tell me what code I need to insert to achieve this?
    I would appreciate any help.
    I'd be inclined to spiral down counterclockwise for a hole, clockwise for a spigot. The only missing data for a G code is tool diameter and start point.
    If you program a G code arc which ends at it's start point the machine goes full circle.
  3. The Following User Says Thank You to Robin Hewitt For This Useful Post:
    hi'ya martin, not 100% sure but see att.pdf, it's a long time since I did anything on an ELU-kelef WARNING check your +/- directions and abs/inc in program. you can post a sample program to be checked
    Attached Thumbnails Attached Thumbnails G02G03.pdf
  5. The Following User Says Thank You to kelef For This Useful Post:
  1. Aluminium cutting
    By Bush Flyer in forum Metalwork Discussion
    Last Post: 13-05-2016, 08:57 AM
  2. Cutting Ply/MDF
    By Leadhead in forum Wood Finishing Tips & Tricks
    Last Post: 02-10-2013, 12:59 PM
  3. control signals to draw a circle
    By lakmalp in forum Machine Control Software
    Last Post: 16-06-2013, 04:52 PM
  4. circle cutting mach 3 problems help please
    By millmateuk in forum Artsoft Mach
    Last Post: 13-06-2013, 06:04 AM
  5. PCB Engraving / Cutting
    By jrob3rts in forum General Discussion
    Last Post: 02-06-2011, 08:35 PM
