    hi iam after a 20t timing belt pulley and a 1500mm long belt or bigger 10mm wide or bigger. iam in the west mids.
    adam
    Got a pair of 23T, take 3/8 pitch, 1/2 inch wide belt (150L) ? 13.5 mm shaft currently fitted with 8mm bushes. Not grub screws, fit by an inner tapered boss, total thickness 1 inch. Got a belt but only about 360mm.
    Tom
    Sherline lathe, Chester DB11V lathe, Myford/ Rodney mill, CNC mill Isel/ home made, Sealy Hack Saw, Meddings Pillar drill.
  1. Best timing belt and pulleys type for minimum backlash
    By paulus.v in forum Belt Drive, Pulleys & Timing
    Last Post: 10-06-2018, 10:18 AM
  2. Belt drive on a router
    By John S in forum Rails, Guideways & Bearings
    Last Post: 10-09-2012, 08:39 PM
  3. any one know where to get a belt drive convertion for x2
    By Scott in forum Sieg Milling Machines
    Last Post: 27-09-2010, 07:44 PM
  4. Belt drive and pulley sizes
    By j2sip in forum Belt Drive, Pulleys & Timing
    Last Post: 20-06-2010, 09:44 AM
  5. Re: Standard Drive Belt Size ?
    By HS93 in forum Belt Drive, Pulleys & Timing
    Last Post: 18-05-2009, 02:30 PM
