    Rikk's Avatar
    Lives in London, United Kingdom. Last Activity: 17-02-2012 Has been a member for 5-6 years. Has a total post count of 5.
    Hope you guys can help, I spent all day yesterday doing as much searching and research as I can so as not to have to post a help thread....but here it is ;(
    Hopefully I've got all the info together needed, if not let me know what else is needed.
    I have one axis setup at the moment (I have tried it with another stepper/driver/axis and it does the same), if I jog the axis in one direction it makes a slick clonk noise and moves VERY slightly (probably one step) then thats it, jogging in the other direction doesn't get any movement. The stepper does make a slight buzzing.humming noise when trying to jog in each direction.
    The stepper is locked ie I can't turn it by hand.
    I've stripped out mach3 and it's driver and reinstalled in case it was that but it's still the same.
    Hopefully someone can point me in the right direction...pretty please ;)
    BOB - Uniport - http://www.zappautomation.co.uk/uniport-v20-p-510.html
    Drivers - 2M880N - http://www.zappautomation.co.uk/2m88...iver-p-20.html
    Steppers :-
    1 x SY85STH80-5504B - http://www.zappautomation.co.uk/sy85...otor-p-31.html
    2 x SY60STH88-3008BF - http://www.zappautomation.co.uk/sy60...otor-p-24.html
    Images of the wiring can be found in this and the next 2 images
    http://rikk.smugmug.com/Scale-4x4/Ma...1_msqVhpp-A-LB
    Screens from mach3
Name:	CNC Wiring.jpg
    Hi
    You have no Port or Pin number assigned to your E-Stop
    The video on your website showing the motors running looks fine.
    Andy
  3. you may have wired the motor phases wrong?
    If you have one phase the wrong way around, it will cancel the other phase out andyou wont get any movement.
    update the wiring to show the colors of the motor wires.
    Rikk's Avatar
    Sorry for the late reply, i didn't realise this had got past the mods yet ;)
    I actually got an answer within about 2 mins of posting this on the mach3 forums(hood is damn quick 8) ), turns out the pul/dir pins in mach3 where round the wrong way, I did follow the pinouts in the instructions but hey...all working now ;)
    Andy, yep nothing in the estop yet, it's set low so working as normally open while I get the bugs out. proper estop on the way for when it gets all plumbed in ;)
    Thanks guys.
    ...........Rikk
  1. Initial thoughts on new build
    By Neale in forum Gantry/Router Machines & Building
    Last Post: 25-01-2014, 10:05 PM
  2. 2 motors on X how do I setup Mach3
    By phill05 in forum Artsoft Mach
    Last Post: 04-02-2013, 08:33 PM
  3. Some initial questions....
    By andy586 in forum Gantry/Router Machines & Building
    Last Post: 27-01-2013, 02:00 PM
  4. FOR SALE: 4th axis setup
    By johngoodrich in forum Items For Sale
    Last Post: 13-06-2012, 05:17 PM
  5. CNC Machine Setup Blog
    By marchantdice in forum General Discussion
    Last Post: 17-10-2011, 07:31 PM
