05-08-2011 #6
I am assuming the press brake is a good press brake, well designed and strong enough and correctly adjusted and skilfully operated to make consistently straight bends to the same angle along the bend even if the sheet has slight variations in its properties across its area, yes. If there are unavoidable slight differences in sheet properties along the folds causing small differences in spring back across the length then so be it.
I just want the best that can be achieved and looking for someone with a good press brake who knows how to get the best results while I am ignoring the nay-sayers with no press brake or who are not offering to quote but who say "don't try 'cos it'll never be perfect".
It is a labour intensive job indeed so I am thinking of things to make it easier for one operator to do, such as keeping the sheet light enough to be flipped over 1000+ times. Is a sheet weighing 7.5 Kg light enough for one man to manage do you think?
What else can be done, perhaps in the way of a table to slide the sheet onto for flipping over can be set up to make the job less tiresome?
This problem has been mentioned to me from several other people but I think that if the press brake has side stop guides fitted and if they are used to keep the sheet aligned correctly then the bends can be kept square and parallel and accumulative errors can be prevented.
I am not going commercial. This is just 12 sheets for my own home DIY. Thanks anyway Robin.
RFQ: Gantry side panels
By fvfdrums in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-01-2014, 03:50 PM -
RFQ: Panels cut from soft plywood
By Rockeyes in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-04-2013, 04:38 AM -
RFQ: MDF Panels (+ More)
By codytom in forum Projects, Jobs & RequestsReplies: 6Last Post: 09-04-2013, 09:16 PM -
Where to get 1/8" sheet mild steel laser/water jet cut?
By HankMcSpank in forum Marketplace DiscussionReplies: 28Last Post: 10-02-2010, 01:28 AM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
