Page 1 of 4 123 ... LastLast
    Ok guys just got myself very confused. I have the following configuration setup on my X axis
    5mm pitch HTD15 belt used:
    16 tooth pulley on stepper going to a 72 toothed pulley, on the same shaft as the 72 is a 24 toothed pulley driving the axis with matched 24 toothed idler. What by your calculations should the ratio be? Things are cutting slightly larger than expected in EMC2 :whistling:
    Thanks in advance
    Doesn't make sense.
    16 driving a 72 with a 24 on the same shaft, OK, now is the final pulley a 24 in which case it's not an idler but driven.
    And if the 24 is an idler then you haven't told up the final driven pulley.
    If the first then it 4.5:1 reduction
    John S -
    Hi John
    I only mentioned the idler for completion. It 16 to72 then 72 to24 which my reckoning is 4.5:1 then 3:1. the total being? this is where im lost :-(
    Still doesn't make sense.
    In the first post you state " on the same shaft as the 72 is a 24 toothed pulley driving the axis with matched 24 toothed idler."
    Now you are saying "16 to72 then 72 to24"
    So have you got a 72 and a 24 on the intermediate shaft or two 72's ?
    John S -
  5. So am i right in thinking (starting with the stepper end) you have geared it down then back up again? :S 16---72----24
    ok a picture speaks a thousands words
ID:	4248Click image for larger version.
    this should make it easier to understand
    ( Deleted what I had posted here as posted at same time as previous)
    It's 16 to 72 then, which is (as JohnS said) 4.5:1 or 0.2222=2/9
    The 24T pulleys just link the two screws so are irrelevant.
    Right so looks to me like 16 driving 72 with a 24 on the same shaft driving another 24 ? [ not in picture ] ?
    If so the two 24's cancel out at 1:1 and the 16 to 72 gives a 4.5 : 1 reduction x by 1 : 1 is still 4.5 reduction.
    John S -
    Cool that is what i was hoping you would say, shall change the config tonight and give it another go. As you can already guess i was trying to do something with the gear up scenario which does not exist.
    If all is well i will take some proper pics and post the results :-)
    Cheers guys
    Here's the update so far, the config set up as 4.5:1 got me closer. over a distance of 150mm on screen the actual travel was 173.5. I've never set up belts before so what next? play with the ratio or the number of steps per mm? it seems a lot to play with the steps. Im using quality pulleys an belt.
  1. 1:1 ratio - pulley sizes
    By dsc in forum Belt Drive, Pulleys & Timing
    Last Post: 12-04-2014, 01:30 PM
  2. Cutting HTD pulley(s)
    By Jonathan in forum Metalwork Project Showcase
    Last Post: 11-12-2012, 07:19 PM
  3. pulley dims for boxford csb
    By onecut in forum Boxford Lathes
    Last Post: 23-09-2012, 04:58 PM
  4. 4th Axis timing pulley + Axminster bandsaw review
    Last Post: 09-04-2011, 07:31 PM
  5. WANTED: Timing Pulley Suppliers?
    By m_c in forum Items Wanted
    Last Post: 02-11-2008, 01:02 AM
