Page 3 of 25 FirstFirst 1234513 ... LastLast
  1. #21
    Looking good so far. I would add some cross supports near the bottom of the legs on all sides to prevent any movement. The natural movement of the drives will cause the frame to sway and you dont want that to happen.
    Ian
  2. #22
    Ian
    Yes definitely, and some triangulation wouldn't go amiss.
  3. #23
    yes that is what the extrusion is for against the wall and Four more 45x45 on the bed
  4. #24
    bits have arrived BUT I'm waiting for Luke to come home so HE can open the package
    sorry lad's and girls (if any) but this is a Father and son bonding project
    I will post images of items when Luke gets home
    He is at work with the wife until 2.00 pm
    James (excited and eager):tup::tup::heehee::heehee:
  5. #25
    Here's the brackets I've made for you:
Name:	Photo0032 (Large).jpg
Name:	Photo0024 (Large).jpg
Name:	Photo0023 (Large).jpg
Name:	Photo0028 (Large).jpg
    Unfortunately it's 4mm aluminium not 5mm. I was told it was 5mm and didn't check ... hope that's ok
  6. #26
    they look the dog's b's Jonathan
    thank you
  7. #27
    well the ball screw ends where a bit tight.
    The big bearing end had to go in the oven and be persuaded with a big adjuster (lump hammer and a socket) but now the lock nut at the end will not go on (yes) i must of caught the thread when I had the persuader in action
    not to worry I don't think it's going anywhere or should I have it rethreaded :question::question:
    James and Luke
    we are going to start bolting down the supported rails on Sunday:rofl::rofl:
  8. #28
    Quote Originally Posted by luke11cnc View Post
    It varied between 11.992mm and 12.000mm depending on where I measured ... so a slight taper.
    Typical, I'd try it and see. If they don't fall off then no problem. On my RM1610 ballscrew (Y-axis) I had the opposite problem yesterday - the bearing was not as tight as yours and I must have not done the nut up tight enough...took me ages to work out what what causing the Y-axis to loose position.
    Bigger spanner!! But first check that the two grubscrews in the edge of the nut which lock it in position are out. Also check the pieces that the grubscrews push onto the thread are not interfering as if they've rotated a little they will stop the nut. I had that problem on one of the nuts that came with the RM2510 ballscrews, so a bit bigger.
    I've made the extra 4 brackets - 8mm holes and better finish this time. Couplings almost done too...
  9. #29
    More brackets, the two couplings and the ballnut mount (finally) done:
Name:	DSC08287 (Medium).JPG
Name:	DSC08288 (Medium).JPG
    (Sorry they're a bit blurred - the camera wont focus for some reason)
  10. #30
    ok a up date
    after prizing my son out of bed and then 10 min's later off his computer we made some progress
    and did some work in the garage on the CNC machine
    and here is the images of today's progress on the x-axis
    we first (me) with the aid of pritt stick glued the printed templates to the 75x75 angle and then centre punched it, as image 1
    after centre punch the template was removed and we then drill the angle out with a 6.8mm drill as in this next image and yes that is the young man that is building the CNC machine.
    after we drilled the holes (long, long time and lots of oil)
    we bolted the bearings to the angle as in this next image
    after some choice words we finished and he went back to his computer, great I can get some work done (bless him, dad your drill is much better than the drill at school it would take hours to drill one hole, and we did 16 in 11/29 poor me)
    But it was worth it just to see a smile on his little face
    any way sitting down and having a coffee i thought how am I going to get two rail square?
    this is what I came up with
    and after some playing around with G clamps and guide it all worked out fine, smooth movement with NO binding
    looking good
    WHAT DO WE DO NEXT :question::question::question::question::question: :question::question:
    I have one ball screw and the other one is on it's way and Jonathan has cut the support for them both
    James and Luke the short one but never ever tell him please
