Thread: Breakout Board
Hi to all,
I am looking to make a breakout board with full opto-isolation on Outputs and Inputs as well as 2x dedicated 10A relays.
The uses will be able to select from a further combination of;
a) 2 out of 3 comprising 1x 10A relay, Charge pump and 0-10V for Spindle control.
b) Channel Y Step and Dir or Chan Y Step and Relay no4 (10A relay)
i believe this board will adequatly cover Lathe and Milling use.
Who of you would have an interest in using such a board.Last edited by croy; 30-07-2011 at 04:56 PM.
Regards,
Roy Stark
30-07-2011 #2
Roy, What is needed is a RELIABLE board that can handle 2 relays, charge pump and 0 - 10v
Can't see a need for opto's on motor outputs as most decent drivers are opto'd anyway, what is needed is fast opto's on inputs, especially the one needed for threading.
A lot of the boards out there at the moment are right on the edge as regards design and component choice.
Drop me a line off list [email protected]John S -
30-07-2011 #3
It really is not hard to make a reliable breakout board. I designed/made some a few years ago with optoisolation on the I/O since it was before I got the isolated drivers. Simple to not have isolation one outputs...
How fast do you need the inputs?
30-07-2011 #4
30-07-2011 #5
17-08-2011 #6
My board will be ready in September, for those of you who are interested:
Features:
· Onboard high voltage regulator (70V Max)
· Dual power supplies;
o One 5V DC for the Parallel Port associated logiclevel circuitry.
o One isolated 12V DC to drive port-opto circuitry.
· Integrated Charge Pump for added protection, withoverride jumper for testing.
· Full optical isolation of all inputs.
· Buffered 2x relays, rated at 10 Amps 240V AC.
· The user will be able to select from a further combination of;
a) 2 out of 3 comprising 1x 10A relay, Charge pump and 0-10V for Spindlecontrol.
b) Channel Y Step and Dir or Y Step and Relay no4 (10A relay)
· Opto isolators can handle step signals up to 40 KHz
Regards,
Roy Stark
18-08-2011 #7
Croy are you meaning to produce these in numbers, or produce a one-off batch for interested parties, or just supplying schematic details?
Breakout Board
By Tomnewry in forum General ElectronicsReplies: 2Last Post: 12-12-2013, 07:24 PM -
breakout board usb or parallel
By crossleymarko in forum Motor Drivers & ControllersReplies: 13Last Post: 30-07-2013, 12:44 PM -
Breakout Board Comparison
By 200thhorseman in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 27-03-2012, 12:28 AM -
FOR SALE: PMDX-122 Breakout board
By IN-WondeR in forum Items For SaleReplies: 0Last Post: 14-12-2011, 04:05 PM -
eBay: CNC Breakout board cheap - that will do me !
By Lee Roberts in forum Items On eBay UKReplies: 9Last Post: 14-08-2009, 05:52 PM
