Thread: drill size
09-08-2011 #1
I know some one will be able to help
I would like to know the drill size for tapping the following threads
m5
m6
m8
m10
thank you for your help
James & Luke :question::question:
09-08-2011 #2
if you know the pitch of the thread, take it from the diameter.
thread size - pitch = tapping drill size
m5 - 0.8 = 4.2
m6 - 1 = 5
m8 - 1.25 = 6.75
m10 - 1.5 = 8.5
09-08-2011 #3
thank you i2i
drill bits ordered
James
09-08-2011 #4
If I'd noticed your post a bit sooner you could have had a few of mine as I keep plenty of spares for the tapping sizes.
Also thread diameter-pitch is only a guide ... hard materials will be easier to drill slightly (0.1mm) bigger. Since 6.75 is not standard you'll want 6.8mm or 6.9mm.
CNC drill bit conundrum...
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 10Last Post: 06-07-2015, 04:37 PM -
WANTED: Drill press
By D-man in forum Items WantedReplies: 0Last Post: 30-08-2013, 07:45 AM -
Stumpy 3.5mm drill bit?
By craigrobbo in forum Tool & Tooling TechnologyReplies: 8Last Post: 09-04-2013, 01:33 AM -
best drill bits
By oadamo in forum Tool & Tooling TechnologyReplies: 4Last Post: 01-01-2011, 11:25 PM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
