    Hi, I'm looking for someone who can machine a gear selector assembly for me. I can supply the models in IGS, STL etc and the target material is 6082 which I can supply if required.
    The main part requires machining operations on all 4 faces and includes a hemispherical cutout. There are an additional 3 parts only one of which can be described as complex.
    The largest part has a bounding box size of approx 100m x 120mm x 25mm.
    Many thanks, Max
    Drawings (even if they're only sketches), along with an idea of the tolerances you are looking for, would be handy if you have them available.
    Thanks AdieR - Jonathan is handling the work for me.
  1. stability - monolith vs. two-part assembly
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 24-10-2012, 02:03 PM
  2. Mill gear box oil
    By abfa9358 in forum Machine Discussion
    Last Post: 15-05-2011, 03:48 PM
  3. My first gear, a deadbeat escapement gear for my clock
    By clockman in forum Woodworking Project Showcase
    Last Post: 30-01-2011, 10:39 PM
  4. Gear cutting
    By John S in forum CAD & CAM Software
    Last Post: 03-10-2010, 06:55 PM
  5. Where to get gear blanks in UK...
    Last Post: 03-01-2010, 02:19 PM
