    Hi all, i recently purchased a 2nd hand warco minor mill/drill and i am intersted in converting it to cnc. The mill is approx 15 yrs old and in quite good condition. Pillar benchtop style.
    Does anyone have any info/tutorials on how to do it and an exact list of compnents?
    I have been offered some motors, mach 3 software disc and some bits and pieces for 50.
    any advice would be greatly recieved, Cheers.
    I did the Warco Major, there's a build log somewhere.
    There is no specific way to do it, you pays your money and takes your choice.
    I'd strongly suggest a 2 stage operation, first cnc it crudely so you have a cnc mill to cut the parts. Then do the pukka job when you know which bits are the problem areas.
    The first common mistake is to buy a ball screw the same length as the X axis and then discover that with a motor on the end you have severely limited the travel :whistling:
  1. CONVERSION: Harrison Mill Conversion
    By m_c in forum Conversion Build Logs
    Last Post: 27-10-2016, 06:15 PM
  2. CONVERSION: Sx3 mill conversion
    By deisel in forum Conversion Build Logs
    Last Post: 29-04-2014, 09:23 AM
  3. NEW MEMBER: Saying hello, about to start a mill conversion.
    By irgonomics in forum New Member Introductions
    Last Post: 28-04-2013, 02:35 PM
  4. CONVERSION: King Midas mill conversion
    By diy-john in forum Conversion Build Logs
    Last Post: 31-03-2013, 09:36 PM
  5. Help with drill-Mill conversion
    By Ross77 in forum Milling Machines, Builds & Conversions
    Last Post: 02-04-2010, 09:25 AM
