    Hi, can anyone help, I have just bought a sx2 mill and I want too convert it but I'm unsure as to wether I can keep the original screws or I need to change them and if so which ball screws. Any help really appreciated thank you
    i2i's Avatar
    Lives in Cardiff, United Kingdom. Last Activity: 30-08-2018 Has been a member for 9-10 years. Has a total post count of 693. Received thanks 30 times, giving thanks to others 0 times.
    if you shop around i'm pretty sure you can get a kit of parts to convert these mills, and definately ballscrews.
    Thank you but I'm hoping to do this without a kit. From what I have seen it's possible to leave the original screws and attach them using lovejoy connectors, but this still leaves the problem of the Z axis and the length of the lead screw for that and the size of the stepper motors.
    i2i's Avatar
    things to consider on ballscrews over leadscrews are, better power transfer on a ballscrew, greater accuracy, zero backlash, trouble free maintenance.
  5. The Following User Says Thank You to i2i For This Useful Post:
  6. #5
    Also remember that ballscrews can backdrive (depending on the lead angle) which can make using the machine manually more difficult. You may have to lock the slides. I think it's worth considering as for simple parts it's sometimes easier just to do it manually...
  7. The Following User Says Thank You to Jonathan For This Useful Post:
  8. #6
    i2i's Avatar
    Simple answer, use a pendant or the keyboard to use it manually. If you're looking for a CNC machine you have to use ballscrews, as i'm sure Jonathan would do if it were his.
  9. #7
    Yes using the keyboard, or just typing the commands, is good as you've effectively got autofeed on XYZ.
    Quote Originally Posted by i2i View Post
    True, except I've not put ballscrews on my mill yet mainly due to cost. I may never do it as the router has ballscrews and will cut most things...
  10. #8
    Thank you both for your input, a lot to think about. It's been over 30yrs since I used a mill or lathe manually and the learning curve seem a lot steeper now. Could I ask, Jonathan, how much accuracy do you think you have lost, if any, by using the lead screws? And did you lose any of the table range?
  1. Belts or Balls getting me Screwed up! Help I need advice Please.
    By longy in forum Belt Drive, Pulleys & Timing
    Last Post: 15-04-2014, 01:46 PM
  2. Replies: 9
    Last Post: 16-11-2013, 03:27 PM
  3. How to get the balls back in a ballnut?
    By Shinobiwan in forum Lead Screws, Nuts & Supports
    Last Post: 24-03-2013, 03:35 PM
  4. Balls, balls and balls
    By Swarfing in forum Marketplace Discussion
    Last Post: 21-03-2013, 07:45 PM
  5. Lost my balls!!!
    By danielbriggs in forum Lead Screws, Nuts & Supports
    Last Post: 19-08-2010, 01:41 PM
