    Hiya,
    Long time no speakee...i have a challenge & you guys popped straight into my non engineering mind!
    I seek to be able to drill a hole about 4mm diameter, very accurately (ie no divergence) all the way along a 450mm long guitar neck...
    ....so that the resulting bored hole runs just beneath the fretboard (the fretboard is the 3mm veneer dark wood on top of the neck ie where where the guitar puts his fingers)
    Two problems...
    1. What kind of custom rig would be in order (I'm thinking any drilling bit/rig would need to 'hang' vertical so gravity doesn't 'pull' on the bit, causing it to diverge)
    2. Where on earth could I buy a drill bit just 4mm diameter and 500mm long! (or how would you approach making one?!). I have found places that sell 500m bits, but they start at 6mm diameter, which is excessive for my needs.
    Things to consider....
    No snappage - it would be catastrophic to have the bit snap half way along
    Really accurate - it would be even more of a tragedy to see the drill bit surface out of the guitar's fretboard at the end of its travel!
    repeatability - I'd like to do this to a few necks!
    Many thanks,
    Hank.
    Robin Hewitt's Avatar
    Lives in Seaford, Sussex, United Kingdom. Current Activity: Viewing NEW MEMBER: Hi everyone Has been a member for 9-10 years. Has a total post count of 1,614. Received thanks 109 times, giving thanks to others 7 times. Is a beta tester for Machinists Network features. Referred 1 members to the community.
    Hi Hank
    Perhaps you need a gun drill. You blast air through to clear the chips so they don't push you off course. (Oil or oil air mix if drilling guns)
    You spin the wood. The axis of rotation defining a straight line through the part where the wood is moving slowest. IIRC the gun drill shies away from the faster cut and automatically centres itself on the axis.
    I have some long gun drill bits if you want pics.
    Knowlege exhausted
    Robin
    EDIT: PS: Suggest, drill the hole, cut the neck around it
    i allways assumed the tension rod ran down a slot that you would cut into the neck face and cover with the fret board ?
    wouldnt work if your just adding a veneer as the fret board
    i would s**t myself trying to drill over that distance
    you have got me thinking now!!
    if the standard is to bond your fret board over the slot then it would be easy .....
    iv just measured one of mine.... the fret board is 5mm deap, rose wood i think
    you beat me to it rick..... they are just slotted buy the look of them :)
    And you beat me to that!!!
    I'm not joking they were the exact words i thought when i read the post!!!:rofl:
    hahahaha!!! i reckon you owe us a cake hankmcspank for saving you the nightmare:lol:
    no it's not for a truss rod - it's for wires (LED fret markers).
    Agreed, it's an onerous task, but believe me, I'd sh*t myself more by way of heating the fretboard with steam, prizing it off with lever, routing some wire channels, sanding the glue off the fretboard and neck, and then putting it all back together and then aligning it back up - ie aka this guy's way...
    http://acapella.harmony-central.com/...-inlay-project.
    ....drilling a hole down the neck is the way to go!
    I've knocked up a small 12 led (10 channel) led chaser & want to fit some LEDs in the fretmarkers of my cheap guitar as an experiment.
    Quote Originally Posted by HankMcSpank View Post
    Hiya,
    Two problems...
    Many thanks,
    Hank.
    Hi. so the picture below is what you would like to achieve but after the neck is constructed??
    I did always wonder how they did it...
    projectile vomit
    im with you there....
    id use my ovation as a chopping board but id build a teleporter and beam the stuff in there before i touched the paint job on my jackson.
    if you ever get around to drilling though you have got to video that!
    it may seem mean but if you are going to projectile vomit all over that very posh peice of wood i have just got to see it :rofl:
    Well it look like gun drilling is the answer...the problem is the bit holder, I'm not gonna get one of these down B "do you want decking" &Q...
    http://www.youtube.com/watch?v=SE9sTRFeCBg
  1. Brians Pick and Place Project
    By briand in forum Pick & Place Machines
    Last Post: 08-02-2014, 04:45 PM
  2. NEW MEMBER: Hello! Another new guy wishing to pick brains and ask for opinions...
    By seashaw in forum New Member Introductions
    Last Post: 17-10-2013, 11:01 AM
  3. JuKu's pick and place project
    By JuKu in forum Pick & Place Machines
    Last Post: 09-12-2012, 08:42 PM
  4. Pick and place log
    By Robin Hewitt in forum Pick & Place Machines
    Last Post: 22-10-2010, 03:00 PM
  5. need someone with cnc brains help
    By steveie_e in forum Machine Discussion
    Last Post: 08-06-2008, 09:50 AM
