Thread: cutter chipload
    does anyone hve a chart of approxmate chiploads for correct cutting of various woos?
    GWizard is your new friend:
    http://www.cnccookbook.com/CCGWizard.html
    It depends on the cutter diameter as clearly smaller cutters will deflect/snap if you use too high a chipload. As a rough guide:
    MDF:
    12mm cutter 0.4mm chip
    6mm cutter 0.3mm chip
    3mm cutter 0.25mm chip (maybe less)
    Plywood:
    12mm cutter 0.42mm chip
    6mm cutter 0.35mm chip
    3mm cutter 0.3mm chip (maybe less)
    (Can give more examples if required)
    In reality you may end up using a fair bit less than these values as the machine may not be able to achieve these feedrates.
  1. fly cutter advice please
    By luke11cnc in forum Tool & Tooling Technology
    Last Post: 07-12-2014, 12:38 PM
  2. Skimming yer bed.... does anyone use a fly cutter?
    By HankMcSpank in forum Machine Discussion
    Last Post: 08-09-2013, 03:57 PM
  3. cutter for MDF
    By deannos in forum Tool & Tooling Technology
    Last Post: 16-10-2011, 08:33 PM
  4. First Plasma Cutter
    By antsals in forum Plasma Table Machines
    Last Post: 16-05-2011, 06:58 AM
  5. Chipload and DOC for small endmills
    By Jonathan in forum Tool & Tooling Technology
    Last Post: 16-01-2011, 03:12 PM
