Thread: Diy Brushless Spindle
The thing to do with your collection of spindles is index them ... rotary table on the Z-axis with the spindles each mounted 72° apart then just spin it to the one you want - like on a CNC lathe. That basically gets you an automatic tool changer. The only potentially difficult bit is locking the rotary table automatically...and maybe the wiring! Hmm you've given me a project now, as if I didn't have enough to make! Use some sort of rotary switch, or just 5 microswitches to activate each spindle automatically. Even snazzier is if the motors are similar you can use one ESC for the lot, and a bunch of relays to switch between spindles...
I should probably use mine more now I'm almost invariably cutting aluminium on my router. It's only 6000rpm (allegedly 6kW) though which is about half what I'd like...
How much difference do you think using the two double row bearings made versus one? Mine has one double row and something like (can't remember) 5 standard bearings.Last edited by Jonathan; 20-09-2011 at 07:08 PM.
20-09-2011 #2
This motor looks like the same as what you used, and it's cheap:
http://www.hobbyking.com/hobbyking/s...idProduct=5144
I'm tempted to get at least 3 of them, plus one ESC, and mount them all along with my existing spindle.
http://www.ebay.co.uk/itm/C10-ER20-1...ht_1682wt_1037
Could get a bit expensive...Last edited by Jonathan; 20-09-2011 at 07:13 PM.
20-09-2011 #3The thing to do with your collection of spindles is index them ...
it will be interesing to see if there is any inprovement but im sure the resonance paterns i get are from my gantry sides
There are currently 13 users browsing this thread. (0 members and 13 guests)
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
All-In-One Brushless Servo System
By Gytis in forum Stepper & Servo MotorsReplies: 0Last Post: 22-12-2015, 10:21 PM -
DIY Brushless spindle
By booski in forum Brushless Spindles & MotorsReplies: 2Last Post: 30-10-2013, 09:36 AM -
Using RC Brushless motors as spindle
By Jonathan in forum Brushless Spindles & MotorsReplies: 30Last Post: 20-12-2012, 08:51 PM -
Mach 3 control of DC Brushless motor?
By templecorran in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 18-11-2010, 04:20 PM
