    Hi All,
    I have a yellow 'SAFETY' message appear on the right hand side of the 'machine' window in eazicnc 3 just above the MDI window. Normally it is a green 'OK'. I have just pinched nut up, taken rocking out out of main spindle bearings. Spindle still turns freely. Any ideas?
    Best to email the supplier, I assume that is Conqueror Design and Engineering Limited, they will reply pretty smatly.
    Peter
    Cheers Pete, I am a bit embarrassed to say I had the guard resting on the hair-trigger emergency stop button? Oops? Thanks for your concern.
    Next question. I am a complete novice and learning G-code programming without any previous experience. I plan to make some molds to lay up Carbon Fibre and would like to machine Numbers and letters in the mould. Are there any pre-written g-code programs that will control the machine to mill in different fonts. Obviously the code is font-size dependent, but maybe the code has a scale factor in the program?
    Any ideas?
    Easycnc has text option built in, a bit blocky if memory serves.
    If you put them in the mold I think they will have to be 'backwards' as it were so as to read them positivley if you get my meaning.
    I have tried many ways to get a single line text in easycnc but so far have had no luck.
    Doing small text using outline is a bit of a time waster as the cutter keeps going over the same ground twice.
    Just play and see what you end up with
    Peter
  1. DIY CNC Safety Guide
    By tati in forum Gantry/Router Machines & Building
    Last Post: 12-08-2013, 11:02 AM
  2. Message for member SMASH
    By birchy in forum General Discussion
    Last Post: 07-08-2013, 08:40 AM
  3. Add Operator Message in G-code?
    By Tenson in forum Programmers Corner
    Last Post: 07-02-2013, 06:39 PM
  4. Eazicnc on denford easiturn
    By pistolknight in forum Denford Lathes
    Last Post: 24-11-2011, 06:55 PM
  5. eazicnc v mach3
    By coldrain in forum Artsoft Mach
    Last Post: 01-02-2011, 02:33 PM
