Thread: eazicnc 3 'SAFETY' message
Hi All,
I have a yellow 'SAFETY' message appear on the right hand side of the 'machine' window in eazicnc 3 just above the MDI window. Normally it is a green 'OK'. I have just pinched nut up, taken rocking out out of main spindle bearings. Spindle still turns freely. Any ideas?
13-10-2011 #2
Best to email the supplier, I assume that is Conqueror Design and Engineering Limited, they will reply pretty smatly.
Peter
13-10-2011 #3
Cheers Pete, I am a bit embarrassed to say I had the guard resting on the hair-trigger emergency stop button? Oops? Thanks for your concern.
Next question. I am a complete novice and learning G-code programming without any previous experience. I plan to make some molds to lay up Carbon Fibre and would like to machine Numbers and letters in the mould. Are there any pre-written g-code programs that will control the machine to mill in different fonts. Obviously the code is font-size dependent, but maybe the code has a scale factor in the program?
Any ideas?
14-10-2011 #4
Easycnc has text option built in, a bit blocky if memory serves.
If you put them in the mold I think they will have to be 'backwards' as it were so as to read them positivley if you get my meaning.
I have tried many ways to get a single line text in easycnc but so far have had no luck.
Doing small text using outline is a bit of a time waster as the cutter keeps going over the same ground twice.
Just play and see what you end up with
Peter
27-01-2019 #5
Hi Peter:
Do you know if CDE still exists? I have a registered version of Eazicnc3, but my laptop crashed and I've had to reload. I need a new reg number to unlock the 'sketch' and open DXF files functions. Normally Alex just emailed me the number when I've had past crashes but I understand he died.
28-01-2019 #6
Unfortunately Alex did die - His father is now listed as being in charge bets to send a letter to him :-
210 Runley Road, Luton, England, LU1 1UB
Parts of their web site are still functional but little else, last time I tried emailing them I got no reply as I wanted to buy the pendrive to enable Eazicnc3 on any machine, should have done it a lot earlier.
Let me know if you get a reply!
Peter
Did you change any of the laptop components as I understand it the machine should have the same id as last time unless something has changed!Last edited by ptjw7uk; 28-01-2019 at 09:16 AM.
DIY CNC Safety Guide
By tati in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-08-2013, 12:02 PM -
Message for member SMASH
By birchy in forum General DiscussionReplies: 1Last Post: 07-08-2013, 09:40 AM -
Add Operator Message in G-code?
By Tenson in forum Programmers CornerReplies: 6Last Post: 07-02-2013, 07:39 PM -
Eazicnc on denford easiturn
By pistolknight in forum Denford LathesReplies: 2Last Post: 24-11-2011, 07:55 PM -
eazicnc v mach3
By coldrain in forum Artsoft Mach (3 & 4)Replies: 8Last Post: 01-02-2011, 03:33 PM
