    As the title suggests i have put everything into an old PC tower case. Know i have been told i have to earth the cable screening at one end only. But what do i earth this to, the PC case. Do i have to earth the PSU and what about the case. On the PSU i have a connection marked as FG (googled it as frame ground) what do i do with this:confused:
    You should connect the mains earth to the computer case, and connect the now earthed computer case to everything else at one point. That's the screening, PSU and spindle if it's one with a metal body that's not already earthed.
  3. The Following User Says Thank You to Jonathan For This Useful Post:
    Quote Originally Posted by deannos View Post
    Which cable are you referring to? While, in principal if the PSU is built to Class 2 insulation specs it is not necessary to earth it, I would recommend earthing everything. The point of not earthing the screen at both ends is to prevent currents flowing in the screen which could compromise the screening efficiency. If necessary a separate earth conductor could be included. inside the screened cable.
    Russell.
  5. #4
    Quote Originally Posted by russell View Post
    Russell.
    The cable is 4 core screened and i have used this to connect the motors to the drivers and also to connect the drivers to the BOB
  6. #5
    If both the drivers and BOB are inside the case they do not need screened cable between them. The screen of the motor cable should be connected to the case and left unconnected at the machine end. Both the machine and the computer case should be earthed via the mains cable.
    Russell.
  1. Replies: 1
    Last Post: 13-02-2014, 03:40 PM
  2. RFQ: Prototype keyboard case - CNC and laser
    By Photekq in forum Projects, Jobs & Requests
    Last Post: 26-05-2013, 08:18 PM
  3. RFQ: Project Case End Plates Require Making
    By flipflop in forum Projects, Jobs & Requests
    Last Post: 17-08-2010, 09:03 AM
  4. PC case control box
    By lateAtNight in forum Electronic Project Building
    Last Post: 02-02-2010, 03:27 PM
  5. Controller box from PC case
    By Smiler in forum Electronic Project Building
    Last Post: 24-12-2008, 03:46 AM
