Thread: help with cnc laser
10-12-2011 #2
Swinds,
unfortunately you will need the information from the lens and the cutting head to set the focal length. Normally you would be able to adjust the nozzle depth by screwing it in or out of the nozzle holder so that you can get the focal point beyond the nozzle so the actual focal point is inside the material you are cutting, but to do this you would need the focal length to start with.
Can you post a link to what you bought or the manual?
Ian
Laser cutter
By John S in forum Laser Machines & BuildingReplies: 8Last Post: 02-06-2012, 02:16 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
RFQ: Cnc or laser cut steel brackets
By don_jarr in forum Projects, Jobs & RequestsReplies: 4Last Post: 12-04-2012, 09:23 PM -
Laser power
By John S in forum Laser Machines & BuildingReplies: 9Last Post: 26-08-2009, 09:53 PM -
new laser
By mike techserv in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 06-06-2009, 02:17 PM
