Hi All, Im looking for a little help in deciding which machine to go for, or the benefits of each,
Im a graphic designer looking to branch into 3D Plaques, signs, memorabilia and prototypes.
Im looking to machine in wood and plastic, and if the Machine could cope with metal then Im sure I would find it useful.
And hopefully a machine that will cope with at least A3 media.
My budget is sub £1500 for all the equipment needed, although if its possible to acquire a good quality machine for less than £1000 then I would prefer that option.
I have looked at the CNC 6040 in both 3 and 4 axis, my understanding is that X is left/right, Y is Forward/Backward, Z is Up/Down. Therefore Im assuming the 4th axis will help with 3D objects and prototypes.
4 Axis 6040 - £1390 - http://www.ebay.co.uk/itm/4-AXIS-CNC...ht_16280wt_989
3 Axis 6040 - £1210 - http://www.ebay.co.uk/itm/CNC-6040-R...t_15750wt_1079
I have also looked at refurbished machines, the one below requires Software and Interface & Driver Kits, which adds a further £350 from the same seller.
3 Axis MDL-2-TR-UN - £414.50 - http://www.ebay.co.uk/itm/2208824641...#ht_946wt_1079
Which software do you advise? is mach3 any good? or are there better options for a similar price?
Is it best to buy separate kits or ready to use kits?
My apologies for the number of questions, unfortunately the number options is so extensive Im running round in circles not knowing enough to make a decision.
Finally as a budget machine what are opinions of the below option? are there any better options you know of?
3 Axis 3020 - £508 - http://www.ebay.co.uk/itm/1406250330...t_27707wt_1079
Thanks for taking the time to look, I really appreaciate any help you may be able to give.
Kind Regards
Martin
