    Hi guys. This is my first attempt at building anything like this myself. I have a history in motorcycles for 45 years and used to be a mech eng designer. Its a bit diferant without a full blown workshop doing your bidding. This project has a limitation on funds but I will not skimp if possible.
    As it is the first I have decided to make a torsion box base. If this all works then I can upgade to a metal frame later. I also thought that linear rail bearings would be better than bearings on angles.
    I realise that regidity is essential so the y gantry has been constructed from 10mm Ally. Although it came cheap the angle was not exactly 90deg . Bit of patience and it appears to be fairly accurate. When the rails arrive for it the will be measured off the x rails to locate. If it ends up being too heavy then I can cut sections out to lighten the load. It rolls well but inertia maybe a problem.
    I have ordered ballscrew, 2 for the x and 1 for the y. My next decision is stepper size (3nm maybe) and whether to build or buy the z.
    Comments are always welcome. Already had great advice on spindle choice.
    Bruce
ID:	5160   Click image for larger version.
ID:	5161   Click image for larger version.
ID:	5162   Click image for larger version.
ID:	5163   Click image for larger version.
  1. BUILD LOG: Scrap Heap Challenge
    By TrickyCNC in forum DIY Router Build Logs
    Last Post: 16-09-2012, 07:52 AM
  2. NEW MEMBER: Up for a challenge......
    By swatt in forum New Member Introductions
    Last Post: 03-10-2010, 10:57 PM
  3. Fancy a challenge?
    By cassius in forum Machine Discussion
    Last Post: 03-09-2010, 02:44 PM
