    I was hoping someone could give me some help with my Dore Westbury milling machine. Im not sure what the model number is though. (picture attached below)
    I have absolutely no experience with milling machines so am finding things very confusing.
    I need to be able to skim a fraction of material using a fly cutter.
    As I mill across the material (winding away from me) the cut my side of the spindle is deeper than the cut the other side.
    I have done a bit of research and I think the pitch of my machine is out?
    I can see how you would adjust the yaw (which seems fine) but I cannot see how you could adjust the pitch?
    Any help regarding this matter would be very much appreciated.
    Many thanks
    Richard
    You need to put a dial indicator attached to a bar in the chuck to measure the relative height of the bed at a large radius. Measure the 4 points (x+,x-,y+,y-) to find how much it is out in each. To correct it you'll probably need to use shims. Search on google for 'tramming' a milling machine and you'll find lots of information about it.
  1. WANTED: cnc milling machine
    By bigred5765 in forum Items Wanted
    Last Post: 25-04-2014, 10:08 PM
  2. FOR SALE: Seig KX1 CNC Milling Machine
    By D2C in forum Items For Sale
    Last Post: 06-03-2014, 09:26 AM
  3. WANTED: X3 CNC milling machine
    By Nemo1966 in forum Items Wanted
    Last Post: 09-11-2013, 09:42 PM
  4. New CNC Controller for Milling Machine
    By antsals in forum Electronic Project Building
    Last Post: 08-04-2012, 05:09 PM
  5. First CNC milling machine help
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 05-09-2011, 09:06 PM
