07-03-2012 #1
Hi All.
Can anyone tell me please if i can attach a FK12 Bearing onto a Lead screw first and then screw the bearing onto a motor mount?.
I want a substantial motor mount with plenty of material so i might not be able to get access to the backing nut to tighten it when
it's in the mount.
Many Thanks in advance for any replies.
Regards,
Mark.
07-03-2012 #2
Mark do you have a drawing of what you have in mind? That would allow us to see what you asking and therefore be able to give a more useful answer to your question.
You are using 16mm leadscrews?
Michael
07-03-2012 #3
Yes fit the FK mount first. Spacer ring, FK mount, spacer ring then nut, then fit it into your motor mount then the four bolts and your done.
Ian
08-03-2012 #4
my thanks Ian for your reply, it just makes a tidier job to combine the bearing onto the motor mounting.
Cheers,
Mark.
08-03-2012 #5
Thanks Michael for responding.
yes i'm using 16x5mm lead 1Mtr screws, Ian has said it's possible to fit the FK12 bearing on first and then bolt this to the side of the motor mount.
Cheers,
Mark.
Which way round to mount a FK12 bearing ?
By EddyCurrent in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 03-03-2014, 09:26 PM -
minimum lead screw size and support bearing sizing
By dsc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 30-03-2013, 04:51 PM -
quick question about lead screw
By japcarmaniac in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 09-02-2013, 11:25 PM -
timing belt instead of lead screw
By deannos in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 06-03-2012, 08:25 AM -
one lead screw or two
By johngoodrich in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 13-08-2011, 02:39 PM
