    Somehow I've never seen one of these before, looks like a nifty piece of kit.
    http://www.ebay.co.uk/itm/2307352556...84.m1436.l2649
    It has the slight inconvenience of mounting a tie bar, but as far as I can tell, no matter how skewed your mounting is, it can't fail to put you on the spindle rotation axis.
    I'd buy one now if only it wasn't so blooming tall :whistling:
    Hang on a bit, a shorter one coming to a store near to me anytime now, might even be cheaper as well. :tup:
    John S -
    C_Bubba's Avatar
    Lives in LaGrange, GA USA, United States. Last Activity: 11 Hours Ago Has been a member for 9-10 years. Has a total post count of 78. Received thanks 10 times, giving thanks to others 2 times.
    Robin,
    My colonial .02 worth. I bought one several years ago and it worked great for its design purpose.
    HOWEVER, I have now gotten into using a probe to do all my edge and center finding work and haven't used it in quite some time.
    I modified one of these (hope the picture comes through):
    by removing the battery and led and putting a probe wire thorough one of the holes. Then I use an appropriate probe command to find either an edge, top, or center of a hole
    PS: A lot cheaper also!
    Art
    AKA Country Bubba
    (Older than Dirt)
    My cup runneth over, a heads up would be much appreciated
    http://www.ebay.co.uk/itm/LONG-20-EL...item2318fbf271
    One of these looks like a goer for a probe mod? but i do like the idea of the gauge one for centering
    Quote Originally Posted by C_Bubba View Post
    Hi Art
    Colonials welcome, but I don't think I dare go back to the States, I had too much fun and got fat:heehee:
    I just bought a probe but does that little ruby ball really sit on the axis of rotation? As soon as the weather warms up so I can get back in my workshop I shall find out :naughty:
    best
    Robin
    Quote Originally Posted by 2e0poz View Post
    The dial does away with all concentricity issues. But I have a round column mill so the long body on the one I found would result in spindle overhang.
    I like to keep everything nice and tight
    LOL! just remember to use plenty of lube to avoid chaffing then
    A wiggler set! Just search rdg or chronos for wigglers, found a set for £5.40, just add a dial gauge, or one of those mag mount digitals (an essential engineering tool with a zillion uses). They are also easy to make, any bit of bar, end doesn't have to be ground special as long as it fits.
    Tom
    Sherline lathe, Chester DB11V lathe, Myford/ Rodney mill, CNC mill Isel/ home made, Sealy Hack Saw, Meddings Pillar drill.
  1. Probe Centering with Mach3 Tutorial
    By Ricardoco in forum Probing, Digitizing & Scaning
    Last Post: 02-07-2016, 07:19 PM
  2. Help with Supply Indicator Lights
    By GTJim in forum General Electronics
    Last Post: 03-09-2013, 08:49 PM
  3. Dial Gauge Vs. Dial Test Indicator?
    By cncJim in forum Tool & Tooling Technology
    Last Post: 24-06-2013, 01:09 PM
  4. Spindle probes for centering
    By maritimesbob in forum Probing, Digitizing & Scaning
    Last Post: 02-09-2012, 11:22 PM
  5. Dial Test Indicator (DTI) swivel clamp
    By Vikash in forum General Discussion
    Last Post: 21-10-2010, 01:59 PM
