Page 3 of 3 FirstFirst 123
  1. The above was made from 20mm thick alu, 20mm Support Rails, SBR20 Bearings.
    The main front part is 150x420mm.
    There have been a few small design changes since the above.
    The main two things is I quickly moved away from the TR16x4 Leadscrews, and upgraded to 1605 Ballscrew.
    And added extra support for the stepper motor.
    I am also no longer using a 1020w wood router for my spindle, but have now upgraded to a 2.2kw water cooled spindle.
    Jamie Aust: Do you have access to any cad programs?
    "If first you don't succeed, redefine success"
  2. #22
    What sort of problems did you get with Trapezoidal screws, as I was going to use them on all axis 16mm.
    As much as I would like ballscrew, it just want work with my budget just now.
    Im looking at x=1200mm, y=900mm, z=300mm ( I may drop each axis down by 100mm )
    nema23 motors x 4, tb6560 drivers x 4 (stand alone drivers) and PSU ( upgrade to G450 soon )
    Cad software I have is Autocad, google sketchup and draftsight.
    From all the reading I have done on Z-axis, I think yours will work best for me.
    jamie
  3. Maybe I should of reworded it a little better.
    I did not move away from the Trapezoidal screws due to a problem as such.
    Just that a 1605 ballscrew with custom machined ends & ballnut, inc postage from Chai was cheaper then I was expecting.
    One thing I would say is stay clear of the tb6560, I think I was one of the 1st on this forum to play about with them drivers, and it was nothing but hassle.
    I do know some people that I using the newer tb6560 boards without a problem.
    But nothing beats having good drivers.
    I am / was using LeadShine 752 Drivers, but I am in a middle of a upgrading with NDA steppers & drivers.
    Just waiting for some more funds, and soon my current cnc router will no longer be classed as a desktop unit, going to need a better shed.
  1. Ross77's Z Axis Design
    By Jonathan in forum Open Source Designs & Plans
    Last Post: 20-05-2013, 05:09 PM
  2. Gantry design advice please
    Last Post: 07-11-2012, 03:17 PM
  3. Advice needed for Z Design
    By Hobgoblin in forum Linear & Rotary Motion
    Last Post: 10-09-2012, 08:18 PM
  4. CNC Design and advice
    By Mad Professor in forum Gantry/Router Machines & Building
    Last Post: 20-09-2010, 02:25 PM
  5. Y axis design
    By GeorgeD in forum Gantry/Router Machines & Building
    Last Post: 15-07-2010, 02:04 AM
