    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Admin Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    FREE USB-Parallel Port Interface
    Released 08/03/2006 - Updated 12/03/2006.
    Do you drive your Motor Controller usually via the Printer Port?
    Well now you can convert it to USB with this very simple Circuit below. We supply the PCB design FREE, the Firmware FREE and the Windows Application FREE
    You just build it, use it and let us know of any improvements we can make.
    To compliment our new FREE Beta USB Application (Shown Below) along with new Firmware, we are going to release a very simple circuit that people can build themselves that will let you control any parallel port stepper motor controller via USB.
    With this simple circuit and our Firmware you will be able to simply plug it into your existing Controller box and using our software, run your Gcode via the USB Port.
    The reason this will work with any existing Controller box that uses the parallel port to control the Clock and Signal lines is because we will release standard Firmware that will cover different pin configurations as needed.
    Find below the first picture of version 1.0
    As you can see, this is not going to cost you a lot of money to make!!!!!!!!!
    PCB and Components.
    Please find below the PCB layout.
    Size of PCB is 75MM * 75MM
    Click here to download the Hi Resolution images: usb-par-hi-respcb600dpi.zip
    These are 600DPI JPG and need to be viewed and printed in Adobe Photoshop for an exact scale.
    Also included are postscript files as well.
    We are also releasing the PCB Layout in Gcode for people wanting to mill their own.
    Milling PCB below with 0.2mm engraving bit.
    Drilling PCB below with 0.8MM drill bit.
    Click here to download the Gcodes: usb-par-gcodev1.zip
    Inside this file are two Gcodes, one for the Milling and the other for the drilling.
    Components:
    1 * 25pin socket
    1 * 18F4550 Chip
    1 * 40 pin Dip Socket.
    1 * USB Socket
    1 * 20mhz Xtal (the Pic internally clocks this upto 48mhz)
    2 * 22pf ceramics
    1 * 4k7 resistor
    1 * 1k resistor
    1 * LED
    1 * 0.1uf ceramic decoupling cap.
    1 * 0.1uf electrolytic capacitor
    1 * 22uf electrolytic capacitor
    1 * little tactile push switch for resetting Pic, not really needed.
    And a PCB about 75mm * 75MM
    Firmware Version 1.2 released 12/03/2006:
    Click here to download the Firmware Version 1.2 Type1: usb-par-firmwarev12-type1.zip
    This code is for use with the 18F4550 Pic Chip.
    You will need a suitable Pic Chip programmer that supports the 18F4550.
    The fuses have all been set in the hex file, so simply load up, Program and Verify.
    Type 1 is configured for the following Pin Configurat
    Pin2: Step X-Axis
    Pin3: Direction X-
    Pin4: Step Y-Axis
    Pin5: Direction Y-Axis
    Pin6: Step Z-Axis
    Pin7: Direction Z-Axis
    Pin10: Z-Limit Switch
    Pin11: Emergency-Stop Switch
    Pin12: Y-Limit Switch
    Pin13: X-Limit Switch
    As we have said before, if you need the firmware customised to suit your controller then please email us and we will re-compile and release here.
    Command Structure for Firmw
    Command Structure Ver 1.2 upwa
    Commands are sent 11 bytes at a t
    This first byte gets broken down into 8 bits and they do the following:
    bit0= X Axis Direction
    bit1= Y Axis Direction
    bit2= Z Axis Direction
    bit3= Travel kind, this is for the firmware to tell it to use different routines for G00 travelling or G01 cutting, 1=Travelling 0=Cutting
    If you set this bit to 1 then the firmware will not care about how it gets to this position and it will just clock each Axis until it gets there.
    If you set it to 0 then it will move the X and Y axis at even pulses to get to it's destination giving the correct line needed. This option takes more processing time, so speed pauses may have to be adjusted.
    bit4= Tells Firmware to ignore limit switches 1=ignore 0=do not ignore
    bit5= always 0
    bit6= always 0
    bit7= always 0
    The next 3 bytes control how many pulses you wish to send to the X-Axis.
    On our machine 533.333 pulses =1mm so to tell it to travel we first have to round up and break to binary int(533.333)=533
    533 binary= 00000000 00000010 00010101
    now we get our 3 bytes from this
    1st byte 00000000 = 00
    2nd byte 00000010 = 02
    3rd byte 00010101 = 21
    By doing it this way we can send a max 16777215 pulses which = 31457MM (103 feet!) Travel
    The next 3 bytes control how many pulses you wish to send to the Y-Axis.
    This is the same as the X-Axis
    The next 2 bytes control how many pulses you wish to send to the Z-Axis.
    Same as the X-Axis but this time only 2 bytes(16bits)
    Final 2 bytes is Pulse Width Delay
    0050 = Pulse delay in Microseconds for speed.
    This will differ depending on the Step Mode that the controller box is set to.
    Find some examples below, obviously we round up because we only send 4 digits to the controller.
    Eighth Step Timings:
    A 2250 Microsecond pause gives 25.4mm or 1 Inch Travel per minute.
    A 1125 Microsecond pause gives 50.8mm or 2 Inch Travel per minute.
    A 0562.5 Microsecond pause gives 101.6mm or 4 Inch Travel per minute
    A 0281.25 Microsecond pause gives 203.2mm or 8 Inch Travel per minute
    A 0140.625 Microsecond pause gives 406.4mm or 16 Inch Travel per minute
    A 0070.3125 Microsecond pause gives 812.8mm or 32 Inch Travel per minute
    A 0035.15625 Microsecond pause gives 1625.6mm or 64 Inch Travel per minute
    A 0017.578125 Microsecond pause gives 3251.2mm or 128 Inch Travel per minute
    So to work out what pause we needed for say 45IPM we would use 2250/45 which gives us 0050
    To work backwards and see what a pause of 50 would get, we would take 2250/50 which would give us 45IPM.
    The motors we use on the CNCDuDeZ Frame max out at about 50 Microsecond pause, which gives us a respectable approx 45IPM!
    Quarter Step Timings:
    A 4500 Microsecond pause gives 25.4mm or 1 Inch Travel per minute.
    A 2250 Microsecond pause gives 50.8mm or 2 Inch Travel per minute.
    A 1125 Microsecond pause gives 101.6mm or 4 Inch Travel per minute
    A 0562.5 Microsecond pause gives 203.2mm or 8 Inch Travel per minute
    A 0281.25 Microsecond pause gives 406.4mm or 16 Inch Travel per minute
    A 0140.625 Microsecond pause gives 812.8mm or 32 Inch Travel per minute
    A 0070.3125 Microsecond pause gives 1625.6mm or 64 Inch Travel per minute
    A 0035.15625 Microsecond pause gives 3251.2mm or 128 Inch Travel per minute
    Half Step Timings:
    A 9000 Microsecond pause gives 25.4mm or 1 Inch Travel per minute.
    A 4500 Microsecond pause gives 50.8mm or 2 Inch Travel per minute.
    A 2250 Microsecond pause gives 101.6mm or 4 Inch Travel per minute
    A 1125 Microsecond pause gives 203.2mm or 8 Inch Travel per minute
    A 0562.5 Microsecond pause gives 406.4mm or 16 Inch Travel per minute
    A 0281.25 Microsecond pause gives 812.8mm or 32 Inch Travel per minute
    A 0140.625 Microsecond pause gives 1625.6mm or 64 Inch Travel per minute
    A 0070.3125 Microsecond pause gives 3251.2mm or 128 Inch Travel per minute
    Full Step Timings:
    Use below full step for speed of 25.4mm or 1 Inch Travel per minute.
    A 9000 Microsecond pause gives 50.8mm or 2 Inch Travel per minute.
    A 4500 Microsecond pause gives 101.6mm or 4 Inch Travel per minute
    A 2250 Microsecond pause gives 203.2mm or 8 Inch Travel per minute
    A 1125 Microsecond pause gives 406.4mm or 16 Inch Travel per minute
    A 0562.5 Microsecond pause gives 812.8mm or 32 Inch Travel per minute
    A 0281.25 Microsecond pause gives 1625.6mm or 64 Inch Travel per minute
    A 0140.625 Microsecond pause gives 3251.2mm or 128 Inch Travel per minute
    Every time you send a 11byte command you will get 2 bytes back from the controller that will give you in ASCII the answer OK. This is the same whether sending Serial or USB.
    You will also get a 2 byte ASCII code sent back for AUX1 inputs which are triggered:
    XL X-Axis Limit Reached
    YL Y-Axis Limit Reached
    ZL Z-Axis Limit Reached
    XY X-Axis and Y-Axis Limits Reached
    XZ X-Axis and Z-Axis Limits Reached
    YZ Y-Axis and Z-Axis Limits Reached
    XA X-Axis, Y-Axis and Z-Axis Limits Reached
    ES Emergency Stop Activated.
    Application:
    Please Check the USB-Software link to download our Beta Application: cncdudezusb17.zip
    Setting up and testing:
    After you have assembled your new Interface, simply plug in a USB lead and Windows XP will automatically detect the Interface as a USB Hid Device.
    You can confirm this by checking in device manager of your machine.
    Now connect your Printer Port cable from the Interface to your controller box and you are ready to go.
    Run up the software, set up the pulses per MM parameter and try out the Jog.
    Please make sure you read the HELP File first.
    .Me
  2. The Following User Says Thank You to Lee Roberts For This Useful Post:
  1. What is the function of a parallel port breakout board?
    By hbx in forum Machine Control Software
    Last Post: 12-03-2013, 06:18 PM
  2. Stepper motor drive using mach3 from parallel port
    By hmarwat370 in forum General Electronics
    Last Post: 04-02-2013, 08:55 AM
  3. parallel port address
    By Dan Brown in forum Artsoft Mach (3 & 4)
    Last Post: 07-01-2010, 12:04 PM
  4. Laptop, ie no parallel port?
    By tompsky in forum Laptops & Tablets
    Last Post: 11-11-2008, 07:12 PM
  5. Which USB parallel port emulator is the best
    By bruce_miranda in forum General Electronics
    Last Post: 18-09-2008, 03:38 PM
