Page 3 of 5 FirstFirst 12345 LastLast
  1. Yes, i saw...
  2. #22
    No worries Sean good to hear you still about.
  3. #23
    Hello Lee,
    i'm currently working on a software that should control 4 motors for a wire machine using our software, see the software here
    http://www.youtube.com/watch?v=WzB3aYCwk8g
    we really would like to sell the software with a dedicated hardware for controlling the 4 stepper and the question is
    if your development could be used as a starting point for this and how much it would cost.
    As you can see, we need 4 motor axis direction control, and we could use some others i/o for heating the wire and limit control.
    if you have interest in this project please contact me at philip_hubert@mac.com
    Thank you for your time
  4. #24
    In the first place happiness for their project. I am a student that I would like to carry out this badge USB. The problem is that my parallel port is different and therefore I cannot make it. My parallel port is the following one:
    Pin1 X Step
    Pin2 Y Enable
    Pin3 Y Dir
    Pin4 Z Dir
    Pin5 Z Step
    Pin6 Z Enable
    Pin7 X Dir
    Pin8 Y Step
    Pin9 spindle MOTOR
    Pin10 X Home
    Pin11 Y HOME
    Pin12 Z HOME
    Pin13 EStop
    Pin14 X ENABLE
    Pin15 EXPAND
    Pin16 EXPAND
    Pin17 EXPAND
    Pin18 to Pin25 GND
    The Firmware could send me for the PIC 18F4550.
    THANK YOU
  5. The Following User Says Thank You to JAVIER For This Useful Post:
  6. #25
    surely it would be easier to make a custom parallel cable to correct the pinouts rather than rewrite the code?
  7. #26
    Hello to everybody.
    I have one problem with my USB to PARALLEL Port DIY Interface. It's recognized correct on PC with Win XP but when I connect it to my laptop with Win 7/32 device has not recognized (Unknow device) as well as I connect it to my desktop PC with Win 7/64. Any sugestions?
  8. #27
    hello. can ı use thıs project with match3
  9. #28
    Hello Sir.
    sir im having trouble, which program do i need to use to control the leds? I have 8 LEDS in my project. I know how to control them using 8 PINS of the Parallel port and also using the Assembly language to create sequence of each LEDS/PINS., but what i want is, i want to control them using USB. Is this module that you have created can possibly control the LEDs?
    I need your help sir. :(
    Thanks a lot...
    GodBless.
  10. #29
    Where can i download this beta from this thread?
    http://www.mycncuk.com/forums/showth...ull=1#post1797
    The link of the download is dead.
    Thanks for the help.
  11. #30
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Has been a member for 9-10 years. Has a total post count of 2,553. Received thanks 167 times, giving thanks to others 656 times. Made a monetary donation to the upkeep of the community. Referred 10 members to the community.
    Hi you can find everything located here: http://www.ukcnc.info/forums/Electronicsoverview.php
  1. What is the function of a parallel port breakout board?
    By hbx in forum Machine Control Software
    Last Post: 12-03-2013, 05:18 PM
  2. Stepper motor drive using mach3 from parallel port
    By hmarwat370 in forum General Electronics
    Last Post: 04-02-2013, 07:55 AM
  3. parallel port address
    By Dan Brown in forum Artsoft Mach
    Last Post: 07-01-2010, 11:04 AM
  4. Laptop, ie no parallel port?
    By tompsky in forum Laptops & Tablets
    Last Post: 11-11-2008, 06:12 PM
  5. Which USB parallel port emulator is the best
    By bruce_miranda in forum General Electronics
    Last Post: 18-09-2008, 02:38 PM
