    This question arises in almost every build log on the forum and every time someone explains why they are unsuitable for most CNC Routers. Here are some simulations I have run to prove the point...
    All rails are 20mm diameter with 150mm between bearing block outer faces. The bearings are attached to a 75x160x20mm plate to which the forces are applied.
    Assumptions:
    Rail / box section ends are perfectly rigidly supported - in reality wont be so deflection will be greater than calculated.
    All joints are perfect, modelled as single entity - in reality will get some deflection between joints.
    The following diagrams each have different scales to make the deflection visible throughout.
    Unsupported rail 200N in Z direction to simulate weight of Z-axis:
Name:	SC20 900mm z200N x50N_steel.jpg
    Supported rail 200N in Z direction to simulate weight of Z-axis:
Name:	SBR20 900mm 200N_steel.jpg
    Unsupported rail 200N in Z direction to simulate weight of Z-axisand 50N in parallel to X for cutting force:
Name:	SC20 900mm 200N_steel.jpg
    Supported rail 200N in Z direction to simulate weight of Z-axis and 50N in parallel to X for cutting force:
Name:	SBR20 900mm z200N x50N_steel.jpg
    Max deflection for supported 0.0074mm vs 0.34mm for unsupported... draw your own conclusion.
  2. The Following 3 Users Say Thank You to Jonathan For This Useful Post:
  1. round rails
    By wilfy in forum Rails, Guideways & Bearings
    Last Post: 01-11-2012, 01:10 AM
  2. Z axis assembly - unsupported rail for very limited movement
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 10-10-2012, 12:44 PM
  3. Limiting unsupported extension on Zaxis.
    By Rogue in forum Gantry/Router Machines & Building
    Last Post: 03-09-2011, 12:30 AM
  4. Unsupported Precision Round Rail Calculator
    By Ross77 in forum Gantry/Router Machines & Building
    Last Post: 24-08-2010, 06:47 PM
