    I've got another job I'm looking for quotes for, 40 of this DXF file out of 1mm Aluminium or Brass (whichever's cheapest).
    If the scale's not clear the central hole is 18mm diameter. Let me know what you think Thanks, Ewan
    Attached Files Attached Files
    download link will not download. It want's me to download third party software first.
    Oh that's bad.. should've tested tbh. Have uploaded to my own server instead: http://www.gimsonrobotics.co.uk/other/bearing-cover.DXF
    Right click save target as should work
    I would get those lasercut instead... getting them milled would probably be more expensive than lasercut...
    And if they where to be milled, then I would need a vacuum table, and unfortunatly, right now, I don't have that.
    Downloaded without installing anything from the initial site for me.
    I was about to suggest laser cutting. I once got some parts laser cut - after contacting several companies the cheapest by a long way was http://www.truecut.co.uk/
    Cheers guys, will give them a go. Will be sure to come back here the next time I've got some CNC-appropriate work!
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Has been a member for 9-10 years. Has a total post count of 2,551. Received thanks 166 times, giving thanks to others 654 times. Made a monetary donation to the upkeep of the community. Referred 10 members to the community.
    Guys,
    I’ve update the original post with the bearing-cover.DXF‎ file as an attachment.
    For some time now our site has supported .DXF file types, so you can upload them to this site and have them hosted in the same way you do your pictures.
    Cheers,
    .Me
    .Me
  1. machined ballscrews
    By wilfy in forum Lead Screws, Nuts & Supports
    Last Post: 30-07-2012, 04:42 PM
  2. RFQ: Small parts CNC machined from iron
    By luc in forum Projects, Jobs & Requests
    Last Post: 20-06-2012, 08:24 PM
  3. RFQ: Parts CNC machined from Nylon
    By egimson in forum Projects, Jobs & Requests
    Last Post: 02-04-2012, 07:40 PM
  4. RFQ: Looking at getting some small parts machined using Brass.
    By ryanlownie in forum Projects, Jobs & Requests
    Last Post: 26-10-2011, 10:44 PM
  5. RFQ: Aluminium parts for my first cnc mill.
    By everyreasonto in forum Projects, Jobs & Requests
    Last Post: 17-07-2011, 10:36 PM
