Thread: Which kit would you recommend?
Hi Guys
I'm planning to convert my manual Sieg SX2 mill (from arceurotrade). Having read round these forums and other sites I think I've got a rough idea of whats required.
I'm just planning on 3 axes.
Initially I want to use the original leadscrews (for x/y)
I envisage mainly milling aluminium, maybe some light work in mild steel.
I'm thinking Nema23 steppers at about 2 - 3Nm will be OK.
Before I start spending, could anyone comment on these kits or suggest alternatives?
http://www.diycnc.co.uk/html/cnc_systems.html system4c enclosed unit kit
http://www.rhonmac-cnc.co.uk/ Kit EX23-5
http://www.worldofcnc.com/cnc-controllers/controller-kits-c-344_388.html
http://www.zappautomation.co.uk/cnc-...l?cPath=139_33
Does anyone sell the electronics/motors prewired and fitted in an enclosure?
Apologies if I've posted to the wrong forum or asked excessively dumb questions!
Ian
08-04-2012 #2
Hi as ive got the system 4 enclosed from roy i can add it is very well built i had it build and running in half a dat took a bit of soldering but was pretty simple, just email roy and he is very helpful and quick at replying, onli sujestions is to get a higher voltage to speed up the rapids, but i find 1500mm a minute ample. Ive had it milling aluminium and steel! Hope this helps.
08-04-2012 #3
Hi Ian,
For the X and Y 3Nm should be fine on ballscrews but on ACME you may need more,for the Z I'd go with something a bit bigger. maybe a NEMA34 4.5Nm...
For the Kit, I'd go to Zapp, the guys there actually know what they are talking about... If you give them a call and tell them that you want to convert a X2 they will be able to tell you what you need (Motors, drivers, BOB...)
Also, If you can afford it, change the X&Y lead screws to Ballscrews. It makes a hell lot of difference. No backlash!
Backlash is OK on Manual mill, but on CNC it is a killer!
Laurent
Can you recommend a UK Supplier for cnc router bits
By GeoDurie in forum Tool & Tooling TechnologyReplies: 0Last Post: 06-06-2014, 10:40 AM -
EXPERIENCE: Would recommend - CNC Company in Notts.
By TonyD in forum Trading Experience & FeedbackReplies: 0Last Post: 15-04-2013, 08:06 PM -
1.5mm Mill End Cutter Can Anyone Recommend a Supplier
By Ridgeback in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-01-2013, 12:53 AM -
Please Recommend me a CNC mill for....
By Gasgasbones in forum General DiscussionReplies: 4Last Post: 29-11-2010, 07:17 PM -
What pitch ballscrew would you recommend?
By AdCNC in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 23-02-2010, 02:08 AM
