Do these things exist to buy ready made or is this something you've got to knock up on a lathe yourself?
http://www.ukcnc.net/forums/showthre...full=1#post333 (post 19 top photo ....4th & 5th photo down you can see how it goes ontot eh stepper shaft.
I could rightly do with some of these with 8mm bores!
14-04-2012 #2
Sorry not seen any available commercially...
Thinking you could just order some round bar; get yourself a centre square and bore them yourself reasonably well if you take your time.
Start off with a smaller drill bit, and then go for an 8mm should be able to get it fairly accurate without the need for a lathe?
.Me
14-04-2012 #3
Do you mean the turned shaft collar holding the spinning bar on the DC motor or the slit connector on the stepper.?
The slit connectors are what you get from Chai (linearmotion bearings) or other Ebay vendors.
14-04-2012 #4
Think he means the coupler/couplings I know someone who used these on a Rockcliff diy machine, can’t remember the full details but he used one of those couplers and it snapped along one of the slits with “not much force at all” as it was explained to me.
So not sure if they are any good or not, I would suggest going with a Jaw type coupler, L050 to be exact, work well sold 300+ of them not had any back (yet).
.Me
14-04-2012 #5
Ye thats what I thought, they are ok really for the money. I had one on my Y axis for 2.5 yrs before it snapped and it had done some hard work, infact my Z axis has still got the original one on from when I bought the screws nearly 3-4 years ago now.
That said I do prefer the Jaw type my self for a few reasons but the ones I've experienced have been ok for the money and I wouldn't waste time trying to make them which I easily could.!
Edit: Hank if it's the other DC collar then I can machine them for you.
14-04-2012 #6
It was this circled in red...
If they existed commercially (with 8mm bores to slide over my stepper shafts), then I'd likely grab a few ....I need to mount different types/varieties of backplates to a stepper shaft (for exploratory winding of coils, pickups etc).
if they don't exist commercially, then I have a big lump of cylindrical ali stock still left here, that I may commision one of you fine fellas to turn down for me (it would be like an elelphantitis version of the thing I circled in red!) ...I have previously made what I need (I'll take a photo later) but because I suck at anything to do with lathes (actually you could extend that out to anything to do with machinery in general!), it didn't turn out that accurate!
14-04-2012 #7
So my initial interpretation was correct then, wasn’t too sure as you said “stepper shaft “.
I couldn’t do this for you as I don’t have a lathe, however could you not make some on your cnc machine?, you could clamp the stock up, do the bore, then fix using the bore, then do the profile work, shouldn’t be too hard to do?
.Me
14-04-2012 #8
What diameter do you need them Hank.? and how many.? I can do them for you no prob thou I'm on the injured list at the minute.!
Got a piece of hot metal in my eye because was being Lazy and couldn't be bother to set bandsaw up to cut piece of flat bar and not slipping my grinding specs on for a quick 30 second cut.!! . . . Wazzak or what 30sec's going to cost me 3 days min.!!!!! . . (Look like cross between Stevie wonder and capatain hook!)
14-04-2012 #9
This is what I made myself ...
It took yonks with a hacksaw to hack throuygh the ali stock!!! (I think it's 100mm diameter)
And here the flip side...I make the blue plates on my CNC (and it's these blue plates that allow me to mount different winding options)
The diameter of the one I made was about 60mm ...but might want them a little wider (not much)
As it goes I'm in no rush ...as I already have what I have (might be nice to have a couple more though) it was only seeing that coupling that propmted this thread that picqued my interest
but my lathe is out of action (& like I say I sucked at making these anyway)
14-04-2012 #10
Jaw couplings are crap. They are designed for shafts that are out of line in one axis, not two axis as often happens in home built machines.
Any out of alignment takes up power to correct, run one at say 10 degrees out and see how hard it is to tun and what heat is generated.
now transpose this into two axis and that creates problems. Jaw couplings or Lovejoy couplings to give them their correct name are not designed for zero backlash, they might be well made but they are not guaranteed to be zero backlash.
The only type of drive that can handle miss-alignment in two axis is the Oldham couplingJohn S -
FOR SALE: ArcEuroTrade 650Ncm 14mm Shaft stepper motor
By m_c in forum Items For SaleReplies: 0Last Post: 13-04-2014, 02:19 PM -
misaligned keyway - stepper shaft vs pulley
By dsc in forum Stepper & Servo MotorsReplies: 9Last Post: 25-02-2014, 03:25 PM -
WANTED: stepper motor with dual shaft (6mm dia) wanted
By HankMcSpank in forum Items WantedReplies: 1Last Post: 08-04-2013, 12:48 AM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
