Page 43 of 55 FirstFirst ... 33414243444553 ... LastLast
  1. Quote Originally Posted by routercnc View Post
    Nice work Joe. You are doing all the right things and asking yourself the right kind of questions. Keep working through it and you'll have a box you can be proud of. Importantly you will be able to fault find or modify at a later date as you have kept it neat and have a wiring diagram to refer back to when you've forgotten what you did. I wish I had put wiring number tags on my cables and put labels on my diagram - something to think about
    Thanks and yes I'll think about the labels, I have various colours too which should help...
  2. #422
    As usual Joe you don't disappoint it a big credit to you
  3. The Following User Says Thank You to Clive S For This Useful Post:
  4. Mains power distribution in the control box is pretty much finished:
  5. #424
    Quote Originally Posted by JoeHarris View Post
    https://youtu.be/sCbZAM9jLQc
    Joe did I spot a fuse in the neutral!! if so I would take it out. You make it look so easy.
  6. The Following User Says Thank You to Clive S For This Useful Post:
  7. #425
    Looking sweet Joe,
    Just so you know the correct format for your videos to show "in post" is like this:
    However your not at all obliged to do anything if you prefer to just drop the link
    .Me
  8. Quote Originally Posted by Lee Roberts View Post
    Looking sweet Joe,
    Thanks Lee, I posted on Tapatalk and not sure how you do that on there?
  9. Quote Originally Posted by Clive S View Post
    Thanks Clive, I am using the double pole fuse holders that came with my cabinet but not using two fuses. Some pictures:
  10. #428
    Ok Joe that's fine but I had to pick it up because it is dangerous to fuse the _ve Good man.
  11. #429
    You would need to insert a URL rather than paste just the link, then once its inserted change [url] to [video]...
    Dont bother though Joe as its really not that big an issue :)
    .Me
  12. The Following User Says Thank You to Lee Roberts For This Useful Post:
  13. Panel progress... estop working nicely (Despite temporarily shorting out the 24v supply and wondering what the squealing noise was..!)
  1. 3-Axis CNC Router - For Helices.
    By Dalmango in forum Gantry/Router Machines & Building
    Last Post: 08-02-2014, 07:27 PM
  2. BUILD LOG: 3 Axis Router
    Last Post: 22-01-2013, 01:08 PM
  3. BUILD LOG: Wobbly: my first 3-axis router
    By Sodster68 in forum DIY Router Build Logs
    Last Post: 20-01-2013, 10:28 AM
  4. 3 axis cnc/router bed
    By dudz in forum Marketplace Discussion
    Last Post: 28-12-2012, 09:38 PM
  5. Need 6' x 4' bed, 4 axis router design.. Help..!
