Page 38 of 66 FirstFirst ... 28363738394048 ... LastLast
  1. my collection of electrical bits so far...
  2. #372
    Quote Originally Posted by JoeHarris View Post
    Looking good Joe
    Does this help your pm question ?Click image for larger version.
    P.s always intended to put hot melt glue over these
  3. The Following User Says Thank You to routercnc For This Useful Post:
  4. Quote Originally Posted by routercnc View Post
    Looking good Joe
    Thanks, they look like beasty cables! I like the idea of using hot glue as insulation.
    The psu is coming together: tx, caps and rectifier all mounted to some ali plate. Getting 50V out of the rectifier. Not connected the capacitors yet.
  5. #374
    Joe be careful after connecting the Caps because they will be charged and will give nasty surprise if you short the wires.
    Edit: To answer your Alarm wire question from below then no I don't.
  6. #375
    Joe, they also take a long time to discharge if nothing is connected to them....
    Neil...
    Build log...here
  7. Quote Originally Posted by JAZZCNC View Post
    Thanks guys I'll be careful!
    And good news on the alarm wiring as that would have been a pain.
  8. Progress on the psu...
  9. I think I've finished the power supply... haven't switched on yet as I want to look it over again with fresh eyes and make sure I haven't done anything dumb! Here she is:
    Power in top right via the D curve mcb which will be din mounted and dc out from the lower terminal block. I have wired a 10k resistor between the dc terminals to drain the caps once powered. Any comments before I turn it on?!
  10. #379
    If you got 50V in post 373 at the rectifier then so long as capacitors are correct way around then should work . . . Only one way to find out
  11. #380
    Only comment (if you have a chance to make any small mods at this stage) is to add a few more sets of terminal contacts for the output, all wired in parallel. This allows you to run separate power feeds to each stepper driver, rather wiring them daisy-chain fashion, and it's easier than trying to stick three big wires in the same terminal. Not sure if it really make a difference in our class of machine but it is generally considered good practice not to share high-power connections between devices, and it's a lot easier if you have multiple terminals available. Might be able to put multiple spade terminals on each of your contacts, though?
  1. BUILD LOG: 3 Axis Router
  4. 3 axis cnc/router bed
