Thread: 3 Axis CNC router
30-01-2018 #541http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
23-02-2018 #542http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
12-04-2019 #543
I'm not sure! Need to do some more testing. After devoting a massive amount of time to building my machine, I got it working and then just felt burnt out with it all and pretty much stopped all together. I have decided I am going to get back to it, finish the job and start actually using my machine!!
13-04-2019 #544
I know the feeling. Best wishes. Yes, I still live and breath though it has been a good bit close a few times these last years. You deserve to enjoy the fruit of a huge amount of labor. So get to it and have fun making chips. Enjoy and good luck. Hopefully you will break fewer bits in the learning curve of feeds and Speeds.
Software SolidWorks 2024, Onshape, Aspire v9.5, Blender
CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
3D printers both FDM/FFD and MSLA resin
CSWA &CSWA-AM certified
www.marino-customs.com
The Following User Says Thank You to m.marino For This Useful Post:
14-04-2019 #545
14-04-2019 #546
15-04-2019 #547
So starting up again, I got the spindle control from Mach set up last night. All seems to work OK, apart from the RPM readout on Mach reads 0 regardless of the spindle speed. Is that normal? The one setting I was not sure about was mach's "spindle pulley" settings. The IP-M manual was not much help on that front. Does anyone know what this should be set to for a 2.2KW chinese water-cooled spindle?
Sadly I think I am going to have to strip down the machine and sort out the bearings as they are binding quite regularly and causing pretty major accuracy issues. You get what you pay for I guess, and I should have shimmed them before I assembled the machine - lesson learned!
15-04-2019 #548
Thanks Clive, good to see you are still on the forum. Looks like Dean hasn't posed in a while...
15-04-2019 #549
Thanks Micheal, a lot of work and no fruit so far, so this summer I hope to change that!!
16-04-2019 #550
Strip down has commenced... feels good to be in it again!
and I have some mild steel tube on order to remake the undersized BK bearing spacers/shims.
14mm o/d with 1mm wall for the 16mm ballscrew bearings
and 18mm o/d with 1.5mm wall for the 20mm screws.
I guess mild steel is what the originals are made from?
The plan is to cut them from the tube slightly oversized and then neaten them up in my ancient lathe so they are nice and uniform in length all the way around. Does that sound reasonable to anyone who has done this before?!
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
