    I'm after a reasonably priced ball nose mill suitable for cutting foam with a cutting length of at least 175mm in the UK
    The only ones I have found are the tools from Frog from the US
    (http://3dcutting.com/products/frogtools)
    Anyone know any good sources in the UK?
    Thanks,
    James
    Thanks chip,
    Those cutters are close, but still about half the length I need, have enquired on the custom option...
    I have searched for that thread, but can't seem to see it, can anyone point me to it?
    Thanks,
    James
    I remember seeing some on eBay some time ago...
    What diameter do you need? Perhaps extending an existing cutter is an option. When I needed a long 1/2" ballnose cutter for MDF I just used a cheap router cutter with a 1/4" shank and made an extension with it using 12mm steel bar. Then hardened it for good measure. I chose 12mm steel bar as being a slightly lower diameter than the cutter the extension cannot interfere with what you're cutting.
    I use long 6mm or 8mm twist drills reground (by eye/hand) to a round end. Works for me.
    Alan D.
    High Density Foam? Best result I had was with a Burr bit :s or maybe I just got the whole spindle speed/feed rate wrong :)
    Aha, spindle speed? I don't know - I use a cheap 240volt router run at 100volts. It lasts for ever in that mode. A slow(ish) speed sometimes helps prevent the foam sticking to the bit with heat if you are cutting deep. That varies with the foam density and composition, of course.
    Alan D.
  1. RFQ: 7mm Ball on 4mm bar 15mm long (as 1 part) x 50
    By Fletchirwin in forum Projects, Jobs & Requests
    Last Post: 23-01-2014, 09:00 PM
  2. Extra long end mills for milling foam
    By gavztheouch in forum Marketplace Discussion
    Last Post: 22-01-2014, 08:01 PM
  3. WANTED: 3mm Ball nose bit please
    By Fivetide in forum Items Wanted
    Last Post: 12-12-2012, 04:06 PM
  4. 1.5mm ball end mill supplier in the uk
    By luke11cnc in forum Marketplace Discussion
    Last Post: 21-01-2012, 07:25 PM
  5. Mini Lathe - chuck key, long nose type sourceable?
    By HankMcSpank in forum Milling Machines, Builds & Conversions
    Last Post: 19-10-2009, 12:41 PM
