    Antonio's clocks are in a pdf format. How would you convert this into something that you could generate g code from?
    Bruce
    The more I know, I know, I know the less. (John Owen)
    NB70's Avatar
    Lives in Swansea, United Kingdom. Last Activity: 5 Days Ago Has been a member for 9-10 years. Has a total post count of 45. Received thanks 6 times, giving thanks to others 3 times.
    Bruce,
    Inkscape can open PDFs and save as DXF, but I've had better results with Vectric Cut2D which can open pdfs directly,
    Nathan
    Thanks Nathan. i will give it a try
    I tried cut 2d but it seemed to load every page of the pdf at once.
    Just loaded inkscape and it worked a treat. You can select which page to load and then save them to dxf. Thanks Nathan
    Better Better DXF output is worth plugging in to Inkscape:
    http://tim.cexx.org/?p=590
    thanks musht. I have added the files.
    Bruce
    This is usefull information thanks Nathan! I'll have a look at Inkscape as I've got lots of PDF's I want to convert to DXF's.
    Neil...
    Build log...here
  8. You can do that by advanced Acrobat reader.
    They av options to convert file in whatever your format.
  1. Hi help converting emco f1
    By Ecu-master in forum Milling Machines, Builds & Conversions
    Last Post: 30-03-2014, 11:24 AM
  2. Converting sketchup to dxf
    By motoxy in forum Sketchup
    Last Post: 08-07-2012, 11:04 AM
  3. Converting Cardboard to DXF
    By Yow Ling in forum General Discussion
    Last Post: 15-11-2010, 09:18 AM
  4. NEW MEMBER: CNC converting in Sweden
    By hubben in forum New Member Introductions
    Last Post: 28-09-2010, 05:16 PM
