Page 12 of 13 FirstFirst ... 210111213 LastLast
  1. #111
    Quote Originally Posted by i2i View Post
    i'm going to have 2 pole 1.5hp 3 phase motors on mine, and i fancy drilling through the motor spindle and attaching the atc actuator on the top of the motor so everything is in line
    I will have to stick with pulleys
  2. #112
    i2i's Avatar
    Lives in Cardiff, United Kingdom. Last Activity: 30-08-2018 Has been a member for 9-10 years. Has a total post count of 693. Received thanks 30 times, giving thanks to others 0 times.
    well i've spent a few hours today pulling apart the J head on the first quatro, and it looks like i'll probably be stripping the quill and putting a new bt30 atc spindle into it to replace the R8 spindle. It would be a shame not to utilise the existing head and quill with it's bearings.
    The design of this spindle will probably be longer that the design on other ones, so mine may well be a special.
  3. #113
    Back to the trawling then.... HELLLLPPPP Im going round in circles here...lol
  4. #114
    i2i's Avatar
    no reason why we can't keep going down this line, it just means my ones will be slightly different
  5. #115
    im sure we will get there, as i said i can wait for the best solution anyhow..
    Rick
  6. #116
    i2i's Avatar
    News from my end, i'm having the existing spindles reground to match the 30 taper, when they're back i'll see if they do the job. If so i'm out guys, this will save me a fair bit so i have to try it.
  7. #117
    Did you get anywhere with this?
    I just spotted that the 6000rpm spindle from the same seller linked to earlier has 5% off and more interestingly someone's actually bought and reviewed it:
    EN027# Spindle with synchronous belt for CNC milling BT30 ATC steel ball clamp+ disc spring+drawbar-in Machine Tool Spindle from Industry & Business on Aliexpress.com
    'Fast delivery and nice spindle, but not the dimensions shown on the drawing on the listing. Diameter is 80mm above the flange and 85mm below it. It is in fact a SIPU model SPP8030-060-10F But still a BT30 ATC and 6000rpm so I am happy. :) FYI the timing pulley is a 45 tooth HTD5M and is 35mm wide Thanks'
    Still too much to spend for me to only get 6000rpm...
  8. #118
    i2i's Avatar
    got the spindles back from the grinder and a bt30 hoder rings quite well into them. I'm in two minds now whether to leave the motor/pulley arrangement as is (bridgeport), or remove the pulley section and mount the motor directly on top of the spindle with a drawbar through the motor.
  9. #119
    i2i's Avatar
    Well I got there in the end but via a different route. I ended up buying two HSD router spindles which have a 30 taper and air powered atc. They are 6.8kw and 24000 rpm, and should have a fair bit of power run at slower speeds.
  10. #120
    Both of these I presume?
  1. The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
    By Husky in forum Generic Chinese Spindles
    Last Post: 26-09-2017, 08:05 PM
  2. motor power and chinese spindles power HELP
    By DigiSoft in forum Spindles & Drive Motors
    Last Post: 16-09-2013, 11:17 PM
  3. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 07:58 PM
  4. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 05:20 PM
  5. NEW MEMBER: Spindles
    By Johnp in forum New Member Introductions
    Last Post: 28-06-2009, 10:46 AM
