    Do I need to use a taper tap first or can I just use a middle tap on Ali profile? Thanks
    Having done a bit of tapping on aluminium recently I found a spiral point tap infinitely better than any of the standard 3 hand-taps. You can pop it in a cordless drill and with a drop of oil down the hole it cuts it like soft cheese.
  3. The Following User Says Thank You to Tenson For This Useful Post:
    Told you so.!! Hisn't the difference between standard taps and spiral taps amazing.!!
    Quote Originally Posted by jonbabbz View Post
    Cutweltools at dewsbury is the place to get them from. High quality and not silly money. . . . Tell them it's for aluminium.
  5. #4
    If you are just doing a few tapped holes in an aluminium pofile then a straight flute tap will do the job and is cheaper than a sprial flute, but if you are doing a lot of tapping the spiral tap is the way to go.
    There are also special auto reversing patting attachments you can get that reverses the chuck when you lift the pressure off.
    A little cutting fluid will help too.
  1. eBay: KB Aluminium Profile Supplies
    By KB Aluminium in forum Items On eBay UK
    Last Post: 20-05-2015, 02:46 PM
  2. FOR SALE: Various fasteners & fittings for aluminium profile
    By samiam5032 in forum Items For Sale
    Last Post: 27-02-2014, 06:53 PM
  3. aluminium profile for cutting bed of router
    Last Post: 19-10-2013, 09:52 PM
  4. Aluminium Profile - ValuFrame?
    By Tenson in forum Marketplace Discussion
    Last Post: 28-06-2012, 01:20 PM
  5. Tapping Aluminium extrusion
    By Web Goblin in forum Metalwork Discussion
    Last Post: 03-01-2011, 02:13 PM
