    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 1 Day Ago Has been a member for 6-7 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    Gents,
    I'm currently working on a small machine and need to manufacture the following cutout panel to hold three switches:
    Material: Stainless steel, 1mm thick
    Quantity: 1 + 1 (it's two parts, so I need a single pair)
    Can anyone provide a quote? It's for a home project so I wouldn't want to spend a fortune. Depending on the costs I might want to produce an aluminium prototype first to see if everything fits properly.
    Regards,
    Tom
    Your drawig is not fullt dimensioned. I would be concerned about the thin strips catching in the machine if these canb be wider then i can machine. Can it be thicker than 1mm? Or can it be ally? If ally is ok i can make out of 1.2 and ship out very quickly.
    dsc's Avatar
    thanks for the reply, PM sent!
    Regards,
    dsc.
  1. Replies: 41
    Last Post: 08-02-2014, 10:37 PM
  2. RFQ: Require small Stainless steel buckles machining- can you help please ?
    By Gasgasbones in forum Projects, Jobs & Requests
    Last Post: 15-05-2013, 05:47 AM
  3. RFQ: RFQ: Micro Precision in Stainless Steel.
    By mikewatch in forum Projects, Jobs & Requests
    Last Post: 12-04-2013, 10:49 PM
  4. Drill 4 x 28mm holes through 44mm thick aluminium
    By WandrinAndy in forum Gantry/Router Machines & Building
    Last Post: 30-09-2012, 08:17 AM
  5. Small panel for my CNC
    By jcb121 in forum Gantry/Router Machines & Building
    Last Post: 19-02-2012, 11:21 AM
