    Hi All,
    I tend to cut Acrylic and some wood when I have the time. I currently use double sided tape which works well but is also messy.
    I have an alloy bed on which I mounted a piece of wood (it's actually kitchen worktoo chipboard) which allows me to have the odd moment of "oops, glad I have that piece of wood there" rather than driving into the bed.
    I do plan to remove the wood at some point once I get a pretty good routine in place so, would I look to use some kind of clamps through the bed? It has slots, possibly called "T" slots. If clamping is the best solution, is it just a case of making something to do the job, or are there some great off the shelf products? I'm not looking to spend much so cost is a factor but if there is something available then I'll have a peek.
    James
    Jay's Avatar
    Lives in Chesterfield, United Kingdom. Last Activity: 07-11-2016 Has been a member for 9-10 years. Has a total post count of 19.
    I think these are what your looking for which allow you to clamp work in all manner of arrangments.
    http://www.rdgtools.co.uk/acatalog/M...ping_Kits.html
    Brilliant. Thank you so much for the link. Will see what I have around first.
    Thanks again.
    James
    Jay's Avatar
    You can also use bolts with a head thats bigger than the t slot and just grind to side oposite to each other equal until they slide in.
  1. Workpiece illumination
    By cropwell in forum Workshop & Equipment
    Last Post: 29-09-2013, 09:21 PM
  2. Securing and Aligning Ballnuts
    By WandrinAndy in forum Gantry/Router Machines & Building
    Last Post: 29-09-2012, 10:39 PM
  3. Workpiece hold down by glue
    By Robin Hewitt in forum Machine Discussion
    Last Post: 30-09-2010, 07:22 PM
  4. Securing your network !
    Last Post: 19-11-2008, 12:18 AM
