    Hope someone can help here....
    Wiring up the MPG I bought, I have installed a BOB (one of Gary's) which is a very simple (no opto-isolation etc.) type.
    I have set Mach3 and my Smoothstepper to look for a second port and set them both to take pins 2-9 on port 2 as inputs for the axis selection and step multiplier. It looks from a little bit of research, that I may need a 10K resistor wired like so to get Mach to read pins 2-9 as inputs. My question is what type of resistor should I buy?
    On Ebay I see carbon film, mtal film, carbon composite and so on, is one type more suitable for my use?
    Thanks for any advice.
    Jeff.
    The resistor type for this application isn't important at all, as it's just a pull-up on a logic signal, so doesn't need to be anything special.
    In terms of quality, metal oxide is probably the best, but to be honest, I'd just use a cheaper carbon film one. One with an 1/8th watt, or 1/4 watt, rating will be more than adequate.
    Hope this helps.
    Jeremy
    Cheers Jeremy, thats a lot of help.
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Has been a member for 9-10 years. Has a total post count of 2,551. Received thanks 166 times, giving thanks to others 654 times. Made a monetary donation to the upkeep of the community. Referred 10 members to the community.
    I'v got some 0.25w Carbon film ones if they are of any use?
    .Me
    Thanks for the offer Lee but my love affair with eBay continues with 100 for 1.99 :)
  1. Resistor Question
    By GTJim in forum General Electronics
    Last Post: 07-04-2013, 09:01 AM
  2. Resistor Calculator
    Last Post: 17-04-2012, 04:22 AM
  3. Best type of shed.
    By Philly in forum General Discussion
    Last Post: 18-03-2012, 10:49 AM
  4. ATX power supply - load resistor - do I need one ?
    By rckeith in forum General Electronics
    Last Post: 18-08-2010, 02:21 PM
  5. What type of mill are people using
    By abfa9358 in forum Machine Discussion
    Last Post: 13-06-2009, 12:03 PM
