    Hi guys,
    I have recently bought a tapping machine with a 3 phase motor. I have changed the motor to single phase. The spec of the motor is as follows:
    50hz
    0.18kw
    220-240v
    1.5A
    I need to buy a green and red push bottom switch to attach to the machine but have no idea of the technical name for it? Any ideas? A link to website would be appreciated too.
    Thanks guys.
    It's a "motor starter", ebay is full of them but you need to disallow "starter motor" when you search
    Or search for a 'DOL' as they are also known as
    If the motor is only 0.18KW then you dont actually need a starter. Control gear is only required for motors with ratings above 0.37KW if I remember correctly.
    You don't need a starter switch for such a small motor but it is a good idea to use a "no volt release" or NVR switch so that the motor won't restart after a power cut.
    For example this
    Russell.
  1. Proximity switch NPN or PNP
    By Matt81 in forum General Electronics
    Last Post: 19-04-2014, 10:38 AM
  2. Limit switch issues?!?
    By jonbabbz in forum General Electronics
    Last Post: 06-02-2014, 06:37 PM
  3. Help withController dip switch settings and Mach3 motor tuning
    By liamo1991 in forum Motor Drivers & Controllers
    Last Post: 15-11-2013, 01:22 AM
  4. Limit switch Cable ...
    Last Post: 17-01-2011, 03:37 PM
  5. Limit switch's - best configuration?
    By HiltonSteve in forum General Electronics
    Last Post: 13-08-2009, 12:26 PM
